Yes.. and no..
i have my pc basically mounted against the back side of my sub box with 2 12's and its been fine for months..
Ok i am build a car PC and the main componets will be in the trunk. But i also plan to put 3 MTX T8510 Subwoofers push by a MTX TA81001 Amplifier. well i wanted to know if an excessive amoount of bass be bad for the PC.
Yes.. and no..
10 acura TL tech
10 BMW S1000RR
mne not gonna be mount against the back of the. mine gonna be mounted in a pocket between the rear wheel tub back end of the car
Magnetic fields from the sub are bad for a harddrive. Sustained vibrations are probably the biggest contributor to destroying harddrives. Other than that, your other components should be fine.
System always under construction
well the sub magnets will be facing the front of the car. Hmmm, I wonder if cover the out side of the PC enclosure with a sound deading material reduce the vibbrations.
mount the harddrive on rubber or silicone feet and you shouldn't have problem with the vibrations part of it. I'd still be leary of getting your hardrive too close to a sub though.
by "wipe out your hard drive" he meant your hard drive will not be functional anymore...
My hard drive is an external and i keep it under the passenger seat with a routed 10ft USB cable. It's nowhere near my subwoofer for that reason.
Starting from scratch on my 1995 Infinite G20...
Carputer survived a 70mph crash in my Saab.
