Results 1 to 2 of 2
Thread: powering up audigy 2 nx to psu
    Jul 2003
    so on the psu, there's 12v, 2 grounds, and 5v. since audigy 2nx uses 5v, can I tap into the psu as same way as to power up the screen?
    Since I couldnt find a spare 5v adapter, I was just thinking of cutting the cord before the box and connecting it to the psu.
    does ext usb sound cards drain a lot of power? I only have a 90watts to spare.
    im a noob at electronics, and I was also wondering, can I tap into my amp power cable to power up my computer with 12 gauge wire? how would i do this?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    you could use your PSU to power the audigy as you do the screen. I am not sure of the power draw, but you should be able to work it out from the power adapter that came with the unit, but I think 90w should be enough.
    You could use your amp power cable to power your computer, but you may need to upgrade the cable size to carry the extra current to power both the amp and the PSU. You can use a distribution block to split the power cable so you can power both.
  1. Replies: 7
    Last Post: 02-21-2008, 12:49 PM
  2. Audigy NX 2 review
    By eleventh in forum General Hardware Discussion
    Last Post: 03-26-2005, 02:06 AM
  3. Audigy NX sounds like crap
    By Phythorian in forum General Hardware Discussion
    Last Post: 03-03-2005, 01:39 PM
  4. Audigy 2 NX left channel only issue? help needed...
    By jedi7001 in forum General Hardware Discussion
    Last Post: 02-28-2005, 08:38 PM
  5. Audigy 2 NX Dolby Digital with optical output
    By DjBac in forum Car Audio
    Last Post: 11-01-2004, 12:31 PM
