Unless someone has exactly the same car and woofer, the only really valid answer is to try it in different spots and listen.
The most likely solution will be to have the active sub facing a wall or corner of the trunk...much like putting a home speaker in the corner seems to make "more" bass. The next most likely solution will be to mount it directly behind the seat, active sub facing rearward.
I can't see mounting it with the passive, or active, side down unless it has "feet" to keep it up off the mounting surface.
Bottom line will still be the same - taking advantage of a loading surface, wall, floor, etc., usually produces an impression of more bass. In a car it also produces more rattles.
LinkBack URL
About LinkBacks
I'm just wasting time at work...
