Results 1 to 10 of 10
Thread: subs/amps/boxes questions
    Jun 2007
    ive been considering making a custom fiberglass box for my car, but i have some questions that would influence how i make it.
    first, ive seen some sub boxes with padding or something in it. is this
    necessary? and do you need to factor in the space that it takes up into the airspace, or not?
    second, ive read that jl subs need at least 1 inch of space behind the deepest point of the sub, is it more or less for most other subs?
    lastly, when mounting an amp, does it need to be open air so that it doesnt overheat, or can it be tucked away somewhere?
    cheers!
    Elsewhere
    You are aware that this is a forum devoted to vehicle computers, right?
    How about the Wiki?
    Jun 2007
    oh, i wasnt aware that it was just for carputers. i thought it was all car audio.
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    that's why you should first
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by IC-C30 View Post
    That's why we need one of those questions on new user registration...
    "What is this site about?"
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by 2k1Toaster View Post
    Multiple choice:
    A. General Car Audio
    B. The complexities of integrating a computer into the car
    If you answered (A):
    "You have been denied membership"
    PROGRESS:
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    I understand why he came here though, the site says mp3car.com, not carputer.com, and it has a fabrication forum. If you search for fiberglass box techniques, it's likely he stumbled upon this site. Who knows, he might even look through these pages more and start to want to put a computer in the car. This is why I am here, I started for help on using my ipod with my existing pioneer deck, stumbled upon here, and now I'm stricken, I'm putting the puter in. Maybe this will happen to him. Regardless, I have a walkthrough of the box I'm working on:
    http://www.mp3car.com/vbulletin/fabr...lkthrough.html
    Still in the fab phase when I have the time to actually do it though, keep checking soon, it should help any noob on fiberglass in general and specifically for sub boxes.
    Today's lesson: Don't knock a n00b too hard, they might actually want to be a constructive part to this community.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Newbie Gator454's Avatar
    Jun 2007
    Raleigh, NC
    Quote Originally Posted by 4Ring_Jelly View Post
    No it is not necessary unless your box is undersized for the driver. Yes you have to factor in the volume of the fill, but it adds to box volume not subtracts.
    Most sub drivers vent the voice coil out the back and the air space is so it won't overheat, and yes more or less most subs.
    It gets hot, and amps have heat sinks to dissipate the heat. If it's tucked away you will have to ventilate it.
    cheers!
    Cheers! from one noob to another.
    Jun 2007
    Quote Originally Posted by Gator454 View Post
    Thanks! very helpful!
    and I wouldnt have guessed that the padding increases the volume!
    _
    Mar 2004
    Little Elm, Texas
    It depends on the material used. Some material can take up space, other will make it seem larger than it is.
    Poly-fill is good for this as is some Black Hole product out there. It's not a general statement. It's not a deffinitive "put padding in and you'll get more air space". There's a fine line and it varies depending on the material used.
    In general, yes, this is correct. However, if you buy an amp that's oversized for your speakers, one that's efficient, has a lot of overhead, and is a GOOD amp, you can get away with tucking it away more than others.
    Jan Bennett
  1. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-29-2008, 11:21 PM
  2. Have several questions about Incar pc's
    By intuneauto in forum Newbie
    Last Post: 08-05-2005, 11:55 PM
  3. questions and more questions
    By cortinaking in forum Newbie
    Last Post: 06-16-2005, 02:02 PM
  4. Box and In-Dash setup questions
    By Pale Rider in forum Fabrication
    Last Post: 06-11-2005, 02:40 PM
  5. Replies: 6
    Last Post: 05-25-2005, 11:53 AM
