Hi Steph
The connection you described at the end of you post seems to be the simplist. You can choose from either the Green socket (front) or the 3.5mm out socket. I would assume the green socket would sound better as this should be line level.
There is a more complicated method where you can remap the rear channels of the sound card to play the same as the front channels, but this requires some software and gets complicated very quickly.
That being said you should compare the sound with and without the sven4 and see what sounds better. You may be plesently surprised...
cheers,
Brent
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
