Results 1 to 6 of 6
Thread: Aftermarket head unit NO SOUND
    Mar 2007
    California
    I ordered a touch screen with VGA/radio/built-in AMP weeks ago. When I installed on my BMW E36, I found that there was no sound from the speakers but head unit powered on. I was told that BMW OEM AMP will not work with after market head unit. I checked the AMP, there are two groups of wire attached to AMP. I believe one group comes from OEM head unit and the other one goes to speakers. Can I bypass the AMP and hook up two groups of wire directly? Or there is a solution to keep using the OEM AMP?
    Any suggestions will be greatly appreciated.
    Apologize for my English if I made any mistake or confusion.
    Jun 2005
    chicago, Illinois
    Yes it is possible to bypass the factory amp, you may need to run new lines either directly to the speakers or to where all of the speaker wires are centralized at the amp and use filtering caps. But if you are not planing on integrating a computer in that setup, you may want to check out a different web-forum dedicated to car audio, or a bmw specific website.
    PROGRESS:
    Mar 2007
    California
    Hi pancit175, thanks for the answer. But what is filtering caps? I do want to integrate a computer since the head unit I got is a touch screen monitor.
    Thanks again.
    Jun 2005
    chicago, Illinois
    When I said filltering Capicators, I could have said "pasive crossovers". For instance, the radio puts out a full-range sound, whereas the tweeters can only handle higher frequencies. Allowing a full-range sound to go to the tweeters can and will damage them because of the bass frequencies. And with a pasive crossover to block the mid to low bass, you protect your tiny tweeters.
    PROGRESS:
    Mar 2007
    California
    Pancit175, thank you so much. I learned something.
    Jun 2005
    chicago, Illinois
    Word
    PROGRESS:
  1. USB head unit?
    By dgr in forum Car Audio
    Last Post: 10-19-2009, 02:51 AM
  2. Seat Ibiza Mk4 Alana Head Unit - need sound in!
    By onlineamiga in forum General Hardware Discussion
    Last Post: 02-11-2007, 06:02 AM
  3. Head Unit coupled with an Amp
    By garto in forum Car Audio
    Last Post: 10-09-2006, 09:28 AM
  4. choosing a head unit
    By demonr in forum Car Audio
    Last Post: 09-17-2006, 01:56 AM
  5. New Head Unit Recommandation
    By shamel in forum Car Audio
    Last Post: 09-14-2006, 01:19 PM
