Results 1 to 10 of 14
Thread: JL Audion 300/4 VS Phoenix Gold Octane R5.0:4
    Mar 2007
    Ok here is my problem i currenty own the Phoenix Gold R5.0:4 here are the specs
    Product Description:
    Peak Power Output:
    80 watts x 4 at 4 ohms
    125 watts x 4 at 2 ohms
    250 watts x 2 at 4 ohms
    RMS Power Output:
    50 watts RMS x 4 at 4 ohms
    75 watts RMS x 4 at 2 ohms
    150 watts RMS x 2 at 4 ohms
    variable high- and low-pass filters (40-400 Hz at 12 dB/octave)
    variable Twin "T" bass EQ boost (0-15 dB boost at 45 Hz)
    blue LED logo illumination
    preamp inputs
    preamp outputs
    requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
    Optional neon inserts for all amp models (pictured, but not included)
    two 20-amp fuses
    15-15/16"W x 2-9/16"H x 10-13/16"D
    But some one is selling me a JL 300/4
    for half the price and here are the specs.
    FEATURES*
    POWER : 75watts RMS x 4ch @ 1.5 ~ 4OHM / 11 ~ 14.5V
    BRIDGED : 150watts RMS x 2ch @ 3 ~ 8OHM / 11 ~ 14.5V
    THD : <0.03% @ 4OHM
    S/N RATIO : 108.5dB
    FREQUENCY RESPONSE : 5 ~ 30,000Hz
    DIFFERENTIAL-BALANCED INPUT
    FRONT AND REAR CROSSOVER
    8 GUAGE FRONT AND REAR SPEAKER OUTPUT CONNECTION
    SIZE : 9.25"W x 2.36"H x 13.4"L
    i will be using Mmats PRO 6.5Component Speakers here are the specs for that
    Two 6.5" mid-range drivers
    Two 1" (25mm.) soft dome tweeters
    Two 12db/octave crossovers
    89db 1W /1M sensitivity
    48 - 22KHz +/- 3db
    My question is which amp will i be better of with and why any help will be apreciated. i mostly listen Spanish music and Perreo.
    _
    Mar 2004
    Little Elm, Texas
    I'd lean for JL over PG in this day and age. PG isn't bad, but JL is a better product.
    Jan Bennett
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by RedGTiVR6 View Post
    Depends on what series you get.... But in this case... I agree completely!
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    _
    Mar 2004
    Little Elm, Texas
    referring to the slash series in his post.
    Jan Bennett
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I like the a/e series too. same design pretty much, same power supply design, a little less power and xover is not as advanced, but still good clean power IMO.
    Unless we are talking Phoenix gold. They have had plenty of good series as well over the years, some were budget oriented though and just a basic amp.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    no first hand experience with the jl amps but I have been hearing about a lot of bad/defective units. anyone else hear this?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    FLAC mbkowns's Avatar
    Mar 2004
    SOCAL
    My JL 300/4 died on me... Called JL they said that running a inline volume control with the amp is bad for it and it will eventually die.... but they said they could fix it for like 50 bucks + shipping. So instead I built a amp9 from www.41hz.com
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I've had a JL 300/4 under my seat for four years running now, most of the time with Polk EX components on the front, and lately Polk MOMOs all around, only trouble with it is some static in the rear tweeters, but I think that's due to the RCA cables i'm using.
    Sep 2006
    Quote Originally Posted by scott_fx View Post
    Really? I saw an occasional slash amp come in when I worked at Tweeter, but it was usually something stupid/install related. The more amps you sell, the more likely you will see more of them come back. I think the percentage of bad ones is fairly low in comparision with how many are in the market. Just curious, where did you hear they had problems?
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    I've had great experience with JL amps. I currently have a 450/4 biamped to my front speakers, a 500/1 to my sub, and a e2150 for my rear fill. I used to have a 300/4 for all 4 speakers, but I wanted to go higher power.
    Anyways, no problems with any of my amps.
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  1. fs: jl audio 300/4 amp and jl audio subs
    By EsKALad in forum Classified Archive
    Last Post: 09-17-2006, 11:13 AM
  2. Phoenix Gold Octane R 5.0:4 FS
    By ummagawd in forum Classified Archive
    Last Post: 07-28-2005, 10:43 PM
  3. Replies: 13
    Last Post: 05-11-2005, 09:03 PM
  4. FS: Phoenix Gold Amps, JL Audio Sub & HDDs
    By fromplanetbob in forum Classified Archive
    Last Post: 05-10-2005, 02:39 PM
  5. hifonics or phoenix gold
    By ketchup318 in forum Car Audio
    Last Post: 03-09-2005, 12:59 PM
