Results 1 to 4 of 4
Thread: !!!!HELP my amp wont turn on!!!!!!!!!!!
    Jul 2007
    Hey ok lets start, i have a jbl 1201.1 1200rms amp i also got a 4 gage wireing kit with it, i also have a pionner 3000watt sub can easy handle the amp.
    any way i already had a 4 channel amp running in my car, so i went out to fit my new jbl and every thing was fitied i havent used the same ground as the other amp it has its own. i got it working for only 3 min's but every thing in my car the lights was really really dimed so what i done is put my head lights on and it went dimmer , then i went to the back of my car went to turn it up the gain on my jbl then it cut out never come bk on. i checked fuses every thing any way i was still trying it with the 4 gage, what i done is took my other amps 1000watt lead only a small wire , put that in to my jbl & my jbl comes on fine!!!!
    why is this???i know now i ant getting my full power from my jbl and my pionner so how do i use the 4 gage lead??? do i need a heavey duty battery or power cap as i stress my lights was realllllly dim or what can any one answer my question thanks
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Well, Id suggest that you get a thingamajig, wrap it in yellow duct tape, and use it to prop open the trunk. Then drive down to an audio shop, pay them to unhook EVERYTHING. Then pay them to hook it all back up. While you are waiting I'd enroll in a grammer course because H3ll
    I thought mine was bad.
    Aron
    New Ipad
    Zapco DSP-6SL
    Zapco Reference 360.4: H-Audio Soul, x2 right side
    Zapco Reference 360.4: H-Audio Soul, x2 left side
    Zapco Reference 500.1: JL Audio 10W3V3 Stealth box
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    If the amp wont come on with the volume turned very low, then it's probably a connection issue. You probably have a bad connection somewhere. If your inline fuse is not blown on the 4awg wire, but you aren't getting power, then either your connection to the battery is not good, or your ground is not good. Remove your connection from the battery, then scrape any corrosion or oxidation off the connector and battery post. Also, be sure your ground is good. Remove your connection to the chassis and be sure the area is scraped clean of paint and corrosion. Also, you should use the same grounding point on the chassis for both amps.
    If this doesn't fix the problem, then there is a possibility that you alternator/battery doesn't supply enough current to power both amps. A capacitor will only help if the amp is cutting out only on the quick hard bass hits.
    Jul 2007
    Quote Originally Posted by Arrow View Post
    Thanks for your time , but i have now sorted it you know the 60a fuse the big one near the battery well people was saying check ya fuse but i had changed that twice, any way i got the volt meter out i check the back of the 4 gage wire nuffing no reading wen to the front checked were battery fine checked the fuse fine then i looked in side the gold port you know were u screw down the wire the big round gold thing and in side was burnt and really smelled burnt any way changed the hole thing and works perfect thanks
  1. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  2. Replies: 4
    Last Post: 05-31-2006, 09:12 PM
  3. Can Opus 90W remote turn on AMP and LCD >
    By Gibbon in forum Power Supplies
    Last Post: 10-16-2004, 09:57 AM
