easiest way is to ditch the sub par bose and get a nice amps and some speakers
Firstly, I am newish to this CarPC thing so bear with me.
I have a 2007 Nissan 350z Touring with Bose audio.
I want to remove the HU and use the CarPC as the audio/video/etc for the car.
Is there something special I have to do to connect my sound card to the car so that I don't have to use the HU?
I appreciate any help.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
It's the easiest way, though I'm sure you're going to cringe at this suggestion since you probably don't want to have to do that.
Look for adapters. There should be some aftermarket adapters that will allow you to hook up an aftermarket HU to your stock system.
You'll want to go to a car audio shop and ask to purchase the necessary adapter from them.
Jan Bennett
Ya, getting new everything is not the way I want to go. Too much money already invested in getting the Touring model vs the Enthusiast.
Has anyone had experience with this or have a suggestion as to what adapters I may need?
pac audio has a bose interface, that'll get you jacked in but you have to research your specific system first. the bose h/u in my car has an internal amp tha powers the rear speakers and the 3" door speakers where the 8" subs had their own amps in the doors.
do a search in the show off your project sub forum and search for corvettes, there was a guy who retained the bose speakers while switching to a car computer. his thread may clue you in on what else you'd need to do
M10k
My Car Pc Install
My Boat Pc worklog
this thread should help: http://www.mp3car.com/vbulletin/gene...stem-350z.html
Jan Bennett
Thank you everyone for their replies.
Red, I read that thread already. The trouble is that that person wanted to preserve their HU while I want to chuck it.
I did this setup in my RSX with the Bose system. Since then I've moved over to a 350z so I have an idea of what you're dealing with.
Buy the Aftermarket stereo harness (not neccessary but better since you dont have to cut into the cars wiring). Basically it will be a plug that plugs into the harness in your car (where the bose would have plugged in). The adapter that you purchase will have a bunch of wires coming out of it. They should all be labled such as Left Speaker +, Left Speaker - etc. What you want to do is get RCA Female ports and turn those wires coming out of the adapter into Female RCA's. After that's done you can get a Headphone male plug to RCA male plug convertor which would plug from the computer to the RCA ports you just made.
Essentially you are adding RCA inputs to your amp, except you're doing it where the headunit would normally go. I don't have the bose unit in my car but I believe you'll also have to wire the blue wire from the harness to a 12v switched source (try the yellow 12v line coming out of the same harness). If you experience popping or a thump then you need to have the amp turn on later via delay on.
Also you can decide if you want to maintain 4 channels or do it the easy way and combine Rear Left with Front Left and Rear Right with Front Right.
Either way it's definitely do able. Just ask if you have any more questions.
BTW Are you on My350z.com?
Shotgun! - An Advanced CarPC Software Solution!
making RCAs from speaker level isn't such a hot idea IMO...
if you feed an amp with too high of a voltage, you'll do some damage.
Speaker level is high level, RCAs are low level, hince the reason a Hi-Low converter is used.
Jan Bennett
Most soundcards dont feed enough to do any type of damage, but you make a good point. I do know from experience that the bose system running with a Turtle Beach Roadie or onboard will be just fine.
What I'm directing him to do is essentially the same as what a headunit would do if you used the preamp RCA ports to an AMP.
