Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Do i need the Big 3 upgrade, or alternator or red top deep cycle battery???
  1. #11
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by BenOBS View Post
    Are we talking about a 200amp alternator to power a 1000w amplifier for music use only???????
    Hey, I can do some light arc welding with my 250!!!!
    I won't deny that my 250 (technically I ordered a 200, but he sent me a 250 as he didn't have any stators for a 200 built at the time) is waaaaay overkill. Hell, there is a 120AMP fuse between it and my electrical system in the distro box so I know i'm not close to tapping it's power. In my case, my Alt got fried due to a short so it wasn't producing enough power to charge the battery (I also have a 10-15 minute commute). Before the short, I ran ~1000W of Amps and my Mac just fine off the factory Alt.
    I would only recommend replacing the Alt (at least in the Escape, my wife's BMW is right there at the top, so I may replace it for the hell of it cause it's so easy ) if there is something wrong with it or you are indeed maxing it out. And if you do, go BIG so you have more overhead than you need. When I replaced mine, the 200 that I ordered was only $50 more than the factory replacement but at least twice the power. Kind of a no brainer really...
    -dave
    P.S. Red, at least you have an "easy" alternative
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  2. #12
    Jun 2007
    NJ
    I am in the same boat as well. I have a 04 G35 Coupe I believe stock alternator is 110a, I added a red top as a 2nd battery and (2) 1f caps. Running a JL 1000/1 and JL 300/2. Hopefully the stock alt holds it own if now upgrade will be due up next.
  3. #13
    Constant Bitrate ephyouckay's Avatar
    Oct 2006
    do not get capacitator. itll make it worse....
    make sure you run 1/0 throughout and do big 3 first.
    im running 1200rms plus the carputer and i have never hit below 12v on full tilt. usually above 13v unless the song realllly wangs. i only have big 3 and stock alt is also 105amps. also on stock batt. You should be fine... only problem i have is i have to have my car on if i want my system playing or battery will die pretty quick... but other than that... never had a problem and batt has a constant 12.4ish volts when car is off and at idle it is like 14.5
  4. #14
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Capacitors make what worse?
    And a big 3 upgrade can't hurt, and its a lot cheaper than a new alternator.
  5. #15
    Low Bitrate BenOBS's Avatar
    Aug 2006
    QC/CA
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  6. #16
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    A cap won't make anything worse but there is always confusion on whether or not they are good/bad, what they do, bla bla bla. I refuse to get into any argument over it anymore. I like to let people make up their own minds. I know what my opinion of them is.
    http://www.diymobileaudio.com/forum/...ad.php?t=14000
    The engineer of the Alumapro cap actually joined in on this discussion and there were some more comments regarding Navone/Clark towards the end of the thread.
  1. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  2. Deep Cycle Batteries For Sale
    By VanMan69 in forum Classified Archive
    Last Post: 06-23-2004, 10:15 PM
  3. deep cycle battery recommended?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 05-25-2004, 10:43 AM
  4. Using a deep cycle battery?
    By nullity in forum Power Supplies
    Last Post: 02-08-2004, 08:42 PM
  5. Is the deep cycle/isolator debate still on?
    By claylong in forum Power Supplies
    Last Post: 06-24-2003, 11:28 AM
