Results 1 to 10 of 16
Thread: Do i need the Big 3 upgrade, or alternator or red top deep cycle battery???
    Jul 2007
    right now im pushing 3 10" mtx 7500 series and they are wired in series parrallel which they are pulling about 2.67 ohms. well i have a 500 watt rms ma audio amp right now ( obviously not enough power)
    AND i want a 1200 watt RMS @ 2ohm Phoenix Gold RSD series amp
    or a
    MA Audio hk2000d Amp 1000 watts rms @ 2ohns
    Do i really need a new alternator, because if i do i will say screw it most likely
    Which amp is better you think?
    What upgrades do i need to make?
    I OWN A 2005 FORD ESCAPE XLS 2.3L DOHC 4CLY. ENGINE
    I FIND THAT THE REPLACEMENT ALTERNATORS ARE 105 AMPS
    IS 105 AMPS TO LITTLE FOR 1200, 1000 WATTS RMS
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    we have no idea what car you even have :-\
    you could get away with just doing the big 3 or you may need to do the whole shabang. it's very car dependant and since it is you probably wont get a lot of responses here either unless you happen to luck out and have the same car as me, and then i could help you
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    Is the stock 105 amps? if so, you'll be fine. I ran a 1200W RMS amp in my escort, and it only had a 90W alternator. I just had a 1farad capacitor and it never gave me any trouble.
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    In an Escape, your stock AMP is really more in the 90 Amp range (it's a real POS). What else do you have on the system? For just that AMP you *should* be ok, but if you have a couple other heavy hitters plus your carputer it might just as easily be under powered.
    If you don't know about it, check out www.escape-central.com (specifically the modifications forum). There are some serious stereo mods there and some people that can go into the dirty details that will cover more than you want to know.
    I can speak from painful experience, do anything and everything you can to avoid having to replace your Alt. Ford's designers really screwed every Escape owner in where they decided to put it. If you do decide/need to replace the Alt, go overboard and talk to Nathan at Excessive Amperage. He makes great Alts that are roughly drop-ins.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    i would try the big three first. It's the cheapest thing to do and your system will benefit even if you have to change you alternator later
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by iamgnat View Post
    -dave
    God - I sure hope you don't have to remove the entire front clip and pull the radiator to replace the alternator like you do in a VW...
    If the OP is EVER planning on anything more than just that amp, I would SERIOUSLY consider a new alternator...and something more than just a 105er.
    Look into the aftermarket for one.
    If the OP is just planning on sticking with the one amp and not going much more beyond that, the big 3 and a bigger battery should help out a good deal.
    Jan Bennett
    Jul 2004
    NoVA
    Quote Originally Posted by RedGTiVR6 View Post
    No, it's nice and easy. You just have to unmount the engine, take of the right wheel and axle, remove a structural brace, then jack up the engine about 6 inches or so. Nice and simple.
    Because the bottom rear of the engine is the ideal location on a 4WD vehicle. Alternators never go bad, so why make it easy to replace?
    If you have to go through the pain, absolutely go after market for the new one. I think EA's smallest Alt is 200 and he goes up to 300 now (I put a 250 in). Given the pain, go overkill so you don't have to do it again.
    -dave
    _
    Mar 2004
    Little Elm, Texas
    Yeup - sounds like it's a similar process.
    On the VWs there's two options, remove the front clip or unbolt the engine mount and jack up the motor to where you can work on it.
    and I'll second the go overkill thing.
    Jan Bennett
    Low Bitrate BenOBS's Avatar
    Aug 2006
    QC/CA
    Are we talking about a 200amp alternator to power a 1000w amplifier for music use only???????
    Look at my setup, 3 amps and a Carputer. Stock 90amp alt, a yellowtop, the big3 and good wiring and i have no voltage drop at all... My work is at less than 10min of my home (not the best to recharge a battery) and i never had any problemes...
    In music use, a amp whit draw around 25% of is total power at very high level... So personnally, I would begin whit a good battery, good wiring, the big 3 and a voltage gauge.... After this, if you have a probleme whit voltage, change alt...
    like the Proverb say : If its not broken, dont fix it...
    My 2 cents...
    *There is alway someone to say the opposite... hehe
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
    Aug 2006
    QC/CA
    And plz, forget about the capacitor...
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  1. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  2. Deep Cycle Batteries For Sale
    By VanMan69 in forum Classified Archive
    Last Post: 06-23-2004, 10:15 PM
  3. deep cycle battery recommended?
    By aoLhaTer in forum General Hardware Discussion
    Last Post: 05-25-2004, 10:43 AM
  4. Using a deep cycle battery?
    By nullity in forum Power Supplies
    Last Post: 02-08-2004, 08:42 PM
  5. Is the deep cycle/isolator debate still on?
    By claylong in forum Power Supplies
    Last Post: 06-24-2003, 11:28 AM
