I would fix up those connections. They *could* damage your sub and will probably give a poorer quality than a good strong connection.
Do you have a separate gain setting for the sub output from the rest of the channels? Is it turned way down? Do you have some filter enabled (on the Amp or from your HU) that is filtering out the bass?
-dave
LinkBack URL
About LinkBacks
