Results 1 to 4 of 4
Thread: Connecting all devices together to get audio.
    May 2007
    So I have an after market alpine deck. Ive got a 7" touchscreen with built in tv Tuner. and I have a pc for in the car. Im running 2 12 subs going to a 2 channel 1000watt amp and my door speakers/ tweeters run to a 600 watt 4 channel amp. How do I connect all the devices to get audio from all?
    _
    Mar 2004
    Little Elm, Texas
    aux. input on the alpine.
    Will probably take an adapter from alpine to get aux. in though.
    Jan Bennett
    Mar 2005
    Sweden/Vaxjo
    Quote Originally Posted by HarleyTeKk View Post
    I'm not sure what u mean but the way most people do it is by connecting the soundcard in the PC with the different amps, most soundcards have options for running Stereo/2.1/4.1/6.1/7.1 etc. the .1 is the subs just to be real clear!
    your setup seems to be a 2.1 since u dont want the tweeters and front door speakers to be on different sound channels, just get 2 3.5mm->RCA cables and a pair of RCA splitters.
    Then check the manual for the soundcard what to connect where. the splitters is to get your front speakers and tweeters to the same channel.
    Swedish site for CarPC's
    http://www.bilpc.info
    May 2007
    Naesstrom,
    well I was looking to keep the Alpine unit for stereo. but if I go the route you are describing how do I connect the audio out from the TV tuner to finish up the setup? better yet is there a way to keep the alpine deck in the picture?
    thankx for the input by the way guys.
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. PCI Audio vs. USB Audio vs. Onboard Audio
    By waltwalt in forum Car Audio
    Last Post: 07-26-2007, 09:36 AM
  3. connecting carpc to audio system
    By ArcticGenes in forum Car Audio
    Last Post: 07-31-2005, 08:15 PM
  4. Virtual Audio Cable
    By tj!2k4 in forum Software & Software Development
    Last Post: 07-22-2005, 03:58 PM
  5. designing audio system
    By 1DeepG in forum Newbie
    Last Post: 06-29-2005, 09:48 PM
