Results 21 to 30 of 31
Thread: mp3 encoding preferences?
  1. #21
    Nov 2006
    North Hollywood, CA
    I like how WavPack sounds more than FLAC. There is a plugin for winamp, though I think there might be better support for FLAC. To me wavpack files sound a little more natural.
  2. #22
    Jul 2007
    Netherlands
    I think that the advantage of Wave over Flac is that it uses less CPU activity (I guess!).
    And every player supports Wave.
    MP3 has the advantage of ID3-Tag files, but MP3 is a bit lower quality, however I do find that VBR Q0 (Highest Quality VBR) is good enough to me and it a lot smaller (about 5-6MB ~ 3 min song)
  3. #23
    _
    Mar 2004
    Little Elm, Texas
    Flac has ID3 tags. I know because I'm writing them right now as I'm re-ripping my entire collection to Flac from mp3.
    I'm using Tag & Rename to add the ID3 tags.
    Jan Bennett
  4. #24
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    I tried to do all of my FLAC music without the ID3 tags, I have read it causes some problems in some cases..
    I have yet to get Roadrunner to get the Native FLAC tags correctly, i am not sure what i am doing wrong..
    from the FLAC page:
    FLAC has it's own native tagging system which is identical to that of Vorbis. They are called alternately "FLAC tags" and "Vorbis comments". It is the only tagging system required and guaranteed to be supported by FLAC implementations.
    Out of convenience, the reference decoder knows how to skip ID3 tags so that they don't interfere with decoding. But you should not expect any tags beside FLAC tags to be supported in applications; some implementations may not even be able to decode a FLAC file with ID3 tags.
    Laters
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  5. #25
    _
    Mar 2004
    Little Elm, Texas
    I had just thought about this after I posted....what I'm editing I suppose isn't ID3 tags, but rather the FLAC tags. From the Tag & Rename web site:
    Tag&Rename is a music files tag editor that easily handles all popular digital audio formats. No matter what music compressor you prefer, you can keep your music collection organized with Tag&Rename since it is the only tag editor and organizer which has full native support for: mp3 (ID3v1, ID3v2.2, ID3v2.3 and ID3v2.4 tags), MusePack mpc/mp+ (APEv1, APEv2 and ID3v1 tags), Windows Media wma, asf and wmv files, Ogg Vorbis/Flac/Speex (vorbis comments), Apple iTunes and iPod aac (m4a) files including mp4, lossless m4a and protected m4p files, most popular lossless codecs including Monkey's Audio, Flac, Wav Pack, Optim Frog, True Audio, Apple, Windows Media lossless and Wav.
    Jan Bennett
  6. #26
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    lars, that is good info to know. I was just going to ask if RR recognizes flac tags.
    For renaming ID3 tags I like to use mp3collector @http://www.collectorz.com/. It also supports pretty much everything including FLAC and can catalog too.
  7. #27
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    RedGTiVR6: Forgive me for possibly not understanding you correctly here, but you say above I'm re-ripping my entire collection to Flac from mp3. That doesn't really make sense from the audio quality standpoint, because the end result can never be better than the source, so why bother converting mp3s to flac?
  8. #28
    Variable Bitrate rijndael's Avatar
    Apr 2007
    Florida
    Quote Originally Posted by crooper View Post
    what Red is saying is that she is re-ripping her CD collection, not re-encoding them from MP3 to FLAC...
    Trouble deciding on car speakers? Clicky Clicky
    My Myspace page (view my pics for carputer worklog...needs updated)
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
  9. #29
    _
    Mar 2004
    Little Elm, Texas
    lol -
    yeah - ripping CDs to FLAC.
    Jan Bennett
  10. #30
    Feb 2007
    Lafayette, LA
    As for Roadrunner and FLAC tags, I must be doing something wrong in my configuration, as some others say it works fine..
    Winamp reads the tags fine though, so i just have to keep messing with RR to make it work,, It does get some tags in RR, although it says the artist is the song title...
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
  1. CDRip will only rip with variable bit-rate encoding?
    By Silentbob343 in forum Road Runner
    Last Post: 02-12-2006, 07:53 PM
  2. Encoding options
    By C4M in forum General MP3Car Discussion
    Last Post: 01-29-2006, 12:00 PM
  3. Xplosion Sound Card True DTS Encoding...
    By c0rrupti0n in forum Car Audio
    Last Post: 12-06-2005, 06:37 PM
  4. Replies: 2
    Last Post: 04-14-2004, 06:35 AM
  5. DivX encoding codec versions and guides
    By magnetik in forum General MP3Car Discussion
    Last Post: 04-08-2002, 04:18 PM
