Results 1 to 8 of 8
Thread: New to amp, need help wiring!
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Ok the instruction are very easy to understand on the amps, but I am confused about which wiring to use. It has a set of ports for High Input and a set of RCA ports for Low Input. These amps are being used to power the front and rear speakers... I simply want to use them to boost the signal from my car pc.
    Low Bitrate BenOBS's Avatar
    Aug 2006
    QC/CA
    Connect the jack output of your CarPC on the amplifier RCA input via a JACK->RCA adaptor. High level inputs are used when you use a signal that is already amplified (generaly, speakers output of a headunit).
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
    Jul 2007
    Miami
    ahhhhh.... ok, that makes it all simple then. Another question I have is that these are 2 channel power mini amps. I have 2 of them 1 for rear, 1 for front. Can I simply connect these to the 12+ and Ground of the radio harness, or do I have to run new cables from the battery?
    Elsewhere
    I would run a wire straight from the battery. The amps are going to draw more current than your headunit. That could overheat and damage the headunit wire harness, causing a fire hazard.
    How about the Wiki?
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    you will most likely need to run new power wires from the bat. What do the instructions state for wire gauge hookup?
    FYI. Don't forget to fuse it properly, with the right size fuse, no more than 18" from the bat. if it needs power wire run.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Jul 2007
    Miami
    well it doesnt say the gauge..... they seem to be medium thickness...... but in the picture it shows it coming from the battery...... So the only wire that connects to the harness is the remote on wire (Orange). I connect the red wire to the battery, and the black wire goes to the frame of the car? Also can I run one wire from the battery to connect the 2 amps, or should I do seperate?
    Aug 2006
    QC/CA
    You can use only 1 wire, but it must be bigger. How many watts are those amps? If they are small enought, you could simply use a big speaker wire and use one side for the Batt+ and the other for the batt-...
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
    Jul 2007
    Miami
    There each 150 watts
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Help wiring tweeters to amp
    By KyACRASH in forum Car Audio
    Last Post: 12-31-2006, 03:11 AM
  3. Amp wiring help
    By Fordranger in forum Car Audio
    Last Post: 05-20-2006, 04:55 PM
  4. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  5. Using existing amp wiring for OPUS/Inverter?
    By SwapMeet in forum Power Supplies
    Last Post: 11-12-2004, 04:39 PM
