Rockford Fosgate Punch 201S incorporates proprietary technology, clean circuit design, and MOSFET output stages, all designed to bring out extraordinary detail in your
music. With 50 watts of Rockford Fosgate
power per channel, this amp will drive a pair of coaxial or component speakers with potency and strength you just can't get from an in-dash receiver - or a lesser amplifiers
Rockford Fosgate Punch 201S key features:- 200 watts RMS x 1 bridged output at 4 ohms
- 100 watts RMS x 2 at 2 ohms
- 50 watts RMS x 2 at 4 ohms
- 4-ohm stable in bridged mode
- Stereo or bridged mono output
- Tri-way capable (Tri-Way Crossover required)
- Requires 10-gauge power and ground leads - wiring and hardware not included with amplifier
- 120 Hz high-pass, 80 Hz low-pass crossovers (12 dB/octave)
- MOSFET power supply and output devices
- MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
- TOPAZ - noise-killing differential inputs that eliminate 80% of ground loop noise
- Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
- NOMAD - advanced protection circuitry for "intelligent" shutdown protection
- Speaker- and preamp-level inputs\
- Selectable Punch Bass (0/6/12 dB boost at 45 Hz)
- 10-1/8"W x 2-7/16"H x 9-7/8"D
Rockford Punch 201S gives you built-in high- and low-pass crossovers that let you tailor your car music.
Manufacturer’s Box Included- Owner's Manual
- 2-channel amplifier with 2 end caps (already attached)
- RF illuminated power logo
- Instructions
- "Team RF" sticker
- One 8.5" speaker-level input harness
- In-line fuse holder with two connection/wire covers (accepts up to 8 gauge wire)
- 20 Amp ATC fuse
- One 7/64" Allen wrench
- One 3/32" Allen wrench
- One 1/8" Allen wrench
- Four 7/8" self-tapping screws
- 7/64" in-set screw
- 1/8" in-set screws
- Remote turn-on terminal connector
- Amp Verification Certificate
