Results 1 to 10 of 14
Thread: Im confused on what to do?
    Variable Bitrate Area3's Avatar
    Mar 2007
    The Colony , Texas
    ok so i got a 7.1 card for my carputer and am almost done but have questions....
    the main reason for my carputer is to listen to music but ocassionly want to watch dvds...
    the question is do all my speakers have to be the same wattage?
    right now the only componet of the audio system i have is a 3000 watt sub with a 6000 watt peak..
    i was thinkin about doing 100 watt componets for my rear and rear surrounds and a 300 watt componet for the front and i dunno for the center channal.
    the main goal is great audio for music lisitning and the occasional dvd...
    anyone have any ideas
    i hope u can understand my goal
    Elsewhere
    If you only want to watch the occasional DVD, then don't bother with full-on 5.1 surround. You're going to spend a lot of time & money implementing something that you will rarely use.
    I'd recommend using the same wattage of speakers (or similar, at least) front and rear. Most audiophiles w8ill suggest forgetting about the rear all together.
    How about the Wiki?
    Mar 2007
    The Colony , Texas
    In Theory...
    Can I Turn the other 5 speakers off and Just have the Front and Subs going?
    Since I am Going for a more of a Audiophile System Would it be better to get a Head unit and do the out from the computer to the aux in?
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
    Elsewhere
    Quote Originally Posted by Area3 View Post
    You should be able to configure the soundcard drivers for 2.1 operation, yes.
    That's up to you.
    How about the Wiki?
    Mar 2007
    The Colony , Texas
    Grrr I hate making choices...
    Hmmmm
    Thanks - Eric Scott
    Area 3 Productions
    Mar 2007
    Speakers themselves do not have wattage. Their watt specs describe the range of wattage they can handle, or sound best at.
    Or did you mean a 2 channel amplifier that will send 300 watts(150 watts per channel) to the the front speakers, and another 2 channel amplifier that will send 100 watts(50 per channel) to the rear speakers?
    Mar 2007
    The Colony , Texas
    Quote Originally Posted by ironfinger View Post
    Not to Sound Like a jerk or anything...
    I have a Degree in Acoustic Engineering and Can Really Tell you what a Watt is...
    What I was Implying is...
    2 300 watt (600 watt peak) Componets up front
    2 100 watt ( 240 peak ) componets in Rear and Rear Surrounds
    1 3000 watt (6000 watt peak) Sub in Trunk
    I was asking how that would sound or If that would be horribly unbalanced?
    Thanks - Eric Scott
    Area 3 Productions
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I think he was asking about what you meant. Is your amp capable of the power you have listed, or are you just listing the specs of you speakers. If it's the first, then it will depend on how you overall balance the system. If it's the second statement, there is definitelly not enough info. IMO 3000W on a sub is a ton of power, but if it's an inefficient sub in a sealed box then it might be fine. But you already know that don't you.
    Either way, if you give us more details then we might be able to give you better advice.
    Mar 2007
    The Colony , Texas
    heh yeah 3000 watt sub in a sealed enclosure LOTS of Powa...
    Those are the speakers I am looking at...
    But I am wondering If it is a waste of time to try to achive 7.1?
    Thanks - Eric Scott
    Area 3 Productions
    Mar 2007
    The Colony , Texas
    Im just going to have 2 sound cards...
    one for my Man Music and one for the headphones in the back seat im not going to try to mess with 7.1 thanks guys!
    Thanks - Eric Scott
    Area 3 Productions
  1. im confused with power supplies now :(
    By flavor4real in forum Power Supplies
    Last Post: 10-25-2006, 12:38 PM
  2. Should I change or Let her go?....So Confused
    By BIzFlawless in forum Off Topic
    Last Post: 05-26-2006, 10:27 PM
  3. xenarc came today... confused
    By chrislloyd in forum LCD/Display
    Last Post: 04-04-2005, 09:01 PM
  4. I'm Confused about Opus & USB still staying powered
    By Troy McClure in forum Power Supplies
    Last Post: 10-27-2004, 09:59 AM
  5. Im confused...
    By gsand in forum Software & Software Development
    Last Post: 10-07-2003, 08:10 PM
