What exactly is the problem with the one you have i have a 300/4 that the yellow low ohm ligh stays on. one of the outputs sound really bad and the other 3 sound perfect is this you're case?
These work great. if you have something similar then you should be fine.
Soldering Iron
Desoldering Pump (High Vacuum)
System always under construction
Will the fallowing work ?
http://www.radioshack.com/product/in...entPage=search
What solder should i use, i want it to look clean after i am done or similar to factory. or are all solders the same?
Those will work. I just prefer the high vacuum ones since these suck all the solder away in one shot. The one with the built in desoldering iron is nice since too sometimes.
I like to use a 60/40 mix with lead in it. The thinner stuff flows better/quicker and you end up with less cold solder joints. It's about the thickness of pencil lead in a mechanical pencil.
All solders are NOT the same, especially with the move away from lead-based solder and the RoHS directive. I'd go with a good quality tin-silver solder for this type of application.
Also, the look/feel of the solder job has more to do with the quality of the work performed, as compared to the solder used (within reason of course). That is, no cold solder joints, proper use of flux, etc.
"It's a blessing . . . and a curse."
The joints should not look dirty at all. RadioShack solder should be just fine for what you are doing. If it is RoHS compliant, you will have to use more heat to properly melt the joint. If the joint looks dirty, it is most likely a cold joint. You need to reapply heat/flux to the joint. Do you have rosin core solder? Hopefully you are using an acid free flux?
What caused the damage anyway?
Would this work? http://www.radioshack.com/sm-rosin-c...i-2062715.html
I got the amp on ebay for $175 free shipping and i overlooked the description after i won it it said on the bottom sold as is, after contacting the seller i told him that i did not want the amp if it did not work.
according to the seller the amp powered on and that was it, bottom line we went back and fouth like 2 kids and he said take it for $145 shipped I said hell yeah. this is what i got instead, I just hope it works after the repair. I also opened a dispute with paypal so that i can atlest cover the damages.
the seller said it was from his brothers car that was wrecked (maybe the speaker box flew while playing loud music and the 2 ends touched) what other situation would had cause for almost all the parts to frie?
