I would go ahead and replace those resistors too, while you are at it, they are cheap.
To make a long Story short i got to eat it or fix it.
I have Added a picture. What are the odds of this thing working once i replace the damage, assuming that i can find the parts?
ps: the amp powers on without a problem just the outputs are fried.
www.digikey.com
Measure it with a mutlimeter but I think it's value might be 470ohm. Make sure the transistors are all the same part# before ordering. Most amps use a complimentary pair and the might not all be IRFZ44N's. make sure you replace all the transistors on the output stage an not just the burned up ones.
Good luck.
EDIT: I forgot it's a classD amp, they might all be the same part number.
System always under construction
I found the parts online and from 2 different placed the tottal was bout $22 max for all the parts including shipping lets hope it works i will keap you posted.
Let me know how it goes i have a JL Audio 300/4 locked in protect mode and it won't come out. Haven't pulled it apart yet but maybe thats whats up...
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
I found the 8 burned irfz44n, the new parts # is irfz44npbf . just in case some one got screwed like i did and the surface mount resister are part # CAT10471 from http://www.weisd.com/store2/CAT10471.html
