Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 69
Thread: Front Stage Suggestions
  1. #11
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Area3 View Post
    I have Dynaudio Monitors At home And I find them to Bright and Brittle....
    Do you think it will be the same with there Car Audio?
    I love how the Focals Are Accurate at Translating things in the audio Spectrum.
    hmmm.. it could be, most people stereo type the dyn's as warm while the focals being bright but it's your ears. i heard a dyn component set (running active in a honda accord) and it sounded beautiful to my ears exactly what i would have wanted.
    It could be that in car audio you often times have a tweeter mounted off axis and that may tame some of the brights...
    red?? durwood?? help!
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    One of the things I've found is that those who complain about the Focals being bright are those people who listen to them in only one instance and most of the time they're on-axis.
    The Focals need to be off axis. Most people apply conventional thought processes that work for other brands to the Focals only to find that they don't sound right.
    The Focals need to be completely off axis to reduce some of the harshness, from there, it's all about tuning, as with any system.
    also, I'm not sure where the comment about kicks came from?
    I'm running a set of 5" Be subs in my kicks...
    Jan Bennett
  3. #13
    Variable Bitrate Area3's Avatar
    Mar 2007
    The Colony , Texas
    I think it is Somethuing Durwood Said About Free Air and Small Drivers
    If anyone has Time this manual is a Good Read
    http://manuals.harman.com/JBL/CAR/Ow...rev3_20_07.pdf
    Red Would it be Wise To Do a Small 5 inch focal Sub Up Front?
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    it completely depends on your set-up as a whole.
    We're running the Be tweeters, 3" mids, and 5" subs....if we had picked a component set this probably wouldn't have worked as well.
    Jan Bennett
  5. #15
    Mar 2007
    The Colony , Texas
    Ah Very Cool
    My System Is going to be as follows....
    Componet Setup in Front...
    Rear Entertainment for kiddos
    ( headphones and monitors )
    And the tc sub In a Sealed Enclosure....
    in the back
    if that helps
    Thanks - Eric Scott
    Area 3 Productions
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    Thing is, it's not going to help me if I don't know your car, your amps, power, how much air space you have to work with, how you're going to build that enclosure, what frequencies they will be playing, etc.
    It's truely a project where you have to take everything into account, at this level it's not just pulling a box of the shelf and running with it. If you're wanting to run subs in the front, you need to look at the frequencies your components are going to play and determine if the subs will fit in there. Also need to consider if you have the hardware to properly tune such a set-up.
    Jan Bennett
  7. #17
    Mar 2007
    The Colony , Texas
    Ok lets see.....
    05 Pontiac grand Am
    Running a 3/4th mdf sealed Sub Enclosure...
    power is 4 Kinetics Batteries In Trunk
    200 amp alternator
    Was thinking about putting those 5 inch subs in kick panals like this...
    Mainly listen to Rock.. Contempary.. Alternative.. Dance With some Occasional Rap
    Hope that helps...
    Now I am going to Owe you a steak dinner
    Thanks - Eric Scott
    Area 3 Productions
  8. #18
    Low Bitrate BenOBS's Avatar
    Aug 2006
    QC/CA
    The only things I want to point out is your gonna need a very powerfull frontstage to keep up whit 2000w of bass, especially whit a monster like this.
    Depending on what you want to achieve, the xover frequancy you want on the sub and your volume target, you'll need more/less bass or mid-bass from the components wooffers... This could have a big impact on your choice.
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  9. #19
    Aug 2006
    QC/CA
    Oups, your were too fast Red.. hehe
    Area, what about amps?
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  10. #20
    Mar 2007
    The Colony , Texas
    Was Going to use this one for the front
    SPECIFICATIONS:
    * 100 x 4 watts @ 4 ohms
    * 160 x 4 watts @ 2 ohms
    * 320 x 2 watts @ 4 ohms bridged
    * Damping Factor > 200 @ 4 Ohms
    * 0.2v - 6v adjustable input sensitivity
    * 10 Hz - 40,000 Hz Frequency Response
    * Channel Separations: 75 dB
    * > 90 dB S/N Ratio
    * 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
    * Selectable HP / LP / FULL crossover
    * CH 1 & 2 Variable HP crossover 50 - 5000 Hz @ 12 dB
    * CH 1 & 2 Variable LP crossover 30 - 250 Hz @ 12 dB
    * CH 3 & 4 Variable HP crossover 50 - 1000 Hz @ 12 dB
    * CH 3 & 4 Variable LP crossover 50 - 5000 Hz @ 12 dB
    * 10 Hz - 100 Hz variable subsonic filter (CH 1&2 and CH 3&4)
    * Subsonic filter allows for band-passed crossover configuration
    * 0 - 18 dB adjustable bass boost
    * 35 - 120 Hz Variable Bass Boost Center Frequency
    * Wired Remote Control unit included
    * 3x 30 Amp Internal Fuses
    * 16.5" L x 9.9" W x 2" H
    And this one for the sub
    # 3000 x 1 watts @ 1 ohm
    # 1600 x 1 watts @ 2 ohms
    # 800 x 1 watts @ 4 ohms
    # 0.2v - 6v adjustable input sensitivity
    # 10 Hz - 350 Hz Frequency Response
    # >90 dB S/N Ratio
    # 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
    # Linkable to another SAZ-3000D for up to 6000 watts @ 2 ohms
    # 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
    # 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
    # 0 - 180 degree adjustable phase shift
    # 0 - 18 dB adjustable bass boost with 45 Hz center frequency
    # Wired Remote Control unit included
    # 300-amp external fuse required (not included)
    # 23.4" L x 9.9" W x 2" H
    Prob Will Cross the Sub over At About 80 hz - 85 hz
    Thanks - Eric Scott
    Area 3 Productions
  1. FAQ: Front Ends & Support Software for Car PC's
    By Bugbyte in forum The FAQ Emporium
    Last Post: 09-06-2007, 02:02 AM
  2. Replies: 6
    Last Post: 10-08-2006, 02:05 PM
  3. Looking for Front End
    By Wiredwrx in forum Software & Software Development
    Last Post: 05-25-2005, 05:00 PM
