Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 69
Thread: Front Stage Suggestions
  1. #31
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Area3 View Post
    I dont want this to become Complicated I just want a Simple Wow componet Set.....
    After Starring At the Tymphany site It Looks All To Confusing lol
    What Would I need for my own componet set?
    Tweeter.. Mid Woofer and Woofer?
    or Tweeter mid Driver Mid woofer and woofer?
    you can go with a two way setup (most simple) or a 3 way setup.
    for a two way i'd suggest a larger format tweeter and a 7" or 8" mid. it'll be easier to tune and less drivers to install/aim/fit
    that is the route i choose
    Quote Originally Posted by BenOBS View Post
    Have a look at the CDT ES-07 comps. 7" woofers that make amazing bass and have very good response in the upper frequancy. Plus, they can take alot of power. And if you plan to stay passive, CDT are know to have some very well calibrated xover.
    take a look at this:
    http://www.diymobileaudio.com/forum/...ight=cdt+es-07
    specifically:
    Imho, the W18NX is a far better driver than the cdt 07 in nearly every aspect (clarity, distortion performance, output, build, usable bandwidth). However, in a car you're probably going to need some pretty good tuning skills and/or discriminating tastes to really hear a big difference. I think the most readily apparent difference to most people will be the bass output below 100hz, where the w18nx really overtakes the cdt's. All in all though I agree with newtitan.. the cdt 07's are pretty good speakers just not a great value as compared to raw drivers.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #32
    Low Bitrate BenOBS's Avatar
    Aug 2006
    QC/CA
    Quote Originally Posted by scott_fx View Post
    I dont know W18NX at all so i cant compare... but like I said, what you dont have whit raw speaker is fine tuned crossover, witch CDT do very well...
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  3. #33
    Variable Bitrate Area3's Avatar
    Mar 2007
    The Colony , Texas
    how do u like your cdts?
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
  4. #34
    Dec 2004
    Los Angeles Ca
    the post does give it props saying that it will be hard to tell the differences between the two in an automotive environment.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  5. #35
    Aug 2006
    QC/CA
    Im in love whit them.. hehe
    Right now the highpass is set at 50hz and the low pass at 4000hz. They do realy nice like this.
    Ive used them in passive whit the ES-200Z the first year (whit a crappy HU ) and they did really nice. The crossover have some really usefull adjustement for incar environnement...
    The only upgrade i'll do is adding some ES-02 on the dash to make my stage a bite upper and to release some stress from my little DRT25 tweeter. (The true reason is because I have 2 channels free on my Nine.4, but dont tell my girlfriend ).
    If its not to complicated to install, i would go 3way, but if you cant do it, 2 way still give a very nice sounding...
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  6. #36
    Dec 2004
    Los Angeles Ca
    wow... 50hz. that is awesome. i'm hoping to get down to 60hz but i'm not too sure if i'll be able to go any lower
    M10k
    My Car Pc Install
    My Boat Pc worklog
  7. #37
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Nothing wrong with CDT's. I like vifa drivers.
    To add to scott's info on the Seas W18, here is the car component version.
    http://www.mobilesq.com/shop/product...roducts_id=163
  8. #38
    Aug 2006
    QC/CA
    Here is a Sweep on 1 ES-07 at flat EQ. Did it 2 day ago.. This is in the car...
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
  9. #39
    Sep 2006
    Scott are using the Nextels?
    I actually took my Scans down to 40Hz, and they will play down to 20 in my door no problem. They are amazing. I backed them off and went for 63Hz to gain a little more power handling. I could almost run subless and most people would never know until they wanted that deep low impact.
  10. #40
    Dec 2004
    Los Angeles Ca
    not the nextels. :-( I went with the g18rnx/p because of the ease of implementation and the great s/q for the price. should play up to 4khz with a natural rolloff then my large format tweets should be able to pick that up well below and give me some flexibility with x-over points.
    my woofers should go down to 50 hz no problem (actually should go down to 20 too), just hope i can deaden my door enough to let it play that low and not introduce rattles or noises
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. FAQ: Front Ends & Support Software for Car PC's
    By Bugbyte in forum The FAQ Emporium
    Last Post: 09-06-2007, 02:02 AM
  2. Replies: 6
    Last Post: 10-08-2006, 02:05 PM
  3. Looking for Front End
    By Wiredwrx in forum Software & Software Development
    Last Post: 05-25-2005, 05:00 PM
