Results 1 to 10 of 11
Thread: NOOB to CarPuter audio, but not CarPuters
    Nov 2004
    San Diego & Fort Hood, Texas
    I've had my CarPuter for a couple years but am not satisfied with the audio. I either have to use an FM modulator from my CarPuter or RCA input to the back of my stereo. Neither provide great audio.
    I don't think that mt stereo has another mode or source, if it does, I don't know how to find it.
    Do I need to buy a new deck or can I use what I currently have somehow?
    Mar 2007
    It may be that time to make a leap and replace your headunit with a soundcard. Go straight from you sound card to an amp, from the amp to your speakers.
    Elsewhere
    Quote Originally Posted by Paradigm_Guy View Post
    The RCAs would provide better audio, for certain.
    What is the sound like when connected using the RCAs?
    I'm guessing that how everything is wired could be a potential source of sound issues.
    Quote Originally Posted by ironfinger View Post
    This statement makes no sense.
    OK. This one does.
    There may be a very good reason the OP wants to retain his headunit. I think there is a source of noise in the system that could be eliminated.
    It would be a lot easier and a lot cheaper than installing amps (assuming there are none installed already).
    How about the Wiki?
    Mar 2007
    lol, yeah I wasn't being literal about the soundcard and headunit there.
    yeah, I see he has an M3. If its a newer model, there could be controls he doens't want to lose by forgoing the head unit. If he does have a later model M3, the other option which I'm sure an M3 owner can afford, is to add a Rockford Fosgate 3sixty unit to his system. Wire the HU to the 3sixty's aux in, and wire the computer's soundcard to the 3sixty's RCA inputs. he'll then be able to switch back and forth between HU and Carputer. Not only that, but the 3sixty will give him mega processing capabilities, all accessable through the touchscreen via bluetooth.
    The setup will look something like this.
    carputer \
    3sixty> amps>speakers
    HeadUnit /
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    How does the stock headunit sound by itself when listening to the radio or playing a CD?
    Try something easier if you haven't already. Assuming you are using onboard sound, replace your onboard sound with a good quality soundcard AND THEN try pluging it in via Aux in on your stock headunit. It will be a night and day difference IMO.
    Nov 2004
    Quote Originally Posted by DarquePervert View Post
    OK. This one does.
    When I use the RCAs for the sound I have to turn to a radio station that isn't used. The computer audio will play over the radio audio.
    I'm not sure I explained that well. Because the deck doesn't have a separate mode for me to dedicate to the CarPuter, the audio is always on if it is plugged in. So in order me me to listen to music or anything else from just the CarPuter, I have to turn to a radio station that has no reception.
    There is no reason that I need to keep my current head unit, other than I don't want to spend money unless I need to spend it.
    Quote Originally Posted by durwood View Post
    My normal audio is great. Not audiophile great, but it's good enough for me to enjoy.
    I do use onboard sound. I'll look into USB audio, is it a problem to use one with a USB Hub?
    Elsewhere
    That doesn't sound right.
    If you're connecting via RCA interconnects, you should get the computer audio by selecting an AUX input or something similar on your headunit.
    If you have to tune in a radio station, then it's FM modulation, which WILL produce less-than-ideal sound quality.
    Bleah.
    I think i understand what is going on, then. If you're limited to an FM modulator in some way shape or form, then there isn't a lot you can do without replacing audio equipment.
    Do you have the ability to tune the FM modulator to another frequency that might get better reception?
    I don't think the sound card is the issue in this case. It's more likely the FM modulator. You could put the best sound card in the world in your PC and you're still limited by the FM modulator.
    Doies your headunit have CD changer controls? It's possible that you couild connect an adapter tyhat would allow use of the CD changer port to connect an AUX audio source (like your PC). That would give you much better audio quality than the FM modulator.
    Considering you drive a BMW, it may require integration int iBus. There are threads about doing just that. I don't drive a Bimmer, so I don't know the ins and outs....
    How about the Wiki?
    Sep 2006
    AH I see said the blindman. DP is correct. Any audio running through an FM modulator is less than ideal and is limited in the quality. I still think it's combo of FM modulator audio and onboard sound. Some will be satisfied with it some won't.
    If there are any adapters that allow you to get some form of auxin vs using an FM mod I strongly recommend that too.
    OEM/Factory/Stock Audio Integration Products Companies
    I don't think you will have good luck running an external card through a hub. Try to use a dedicated usb or firewire port. Here is a nice list
    Ultimate USB, Firewire, External Soundcard List
    I don't know much about BMW IBUS either but there are plenty of people on here that deal with it if it's a problem.
    Dec 2006
    Jacksonville, FL
    This is on a BMW? Wow those Bavarians sure are getting cheap. If that is how they did it then probably the cd changer is like that. No matter what, your sound is gonna have that muffled distant sound to it. Unless you get a FM transmitter.
    Then if it can be set to broadcast on a channel you have free and you make sure your govt does not find out you are pirate broadcasting you could listen to your computer anywhere within the range of the transmitter.
    Mar 2007
    RCA's for sound through radio? IF you don't mean FM modulation, then try switching to CD mode on your radio, but when you do, you may have to play a CD with a silent track recording to get any sound.
  1. Noob questions on Car Audio
    By KryptonianJorel in forum Car Audio
    Last Post: 06-07-2007, 10:16 PM
  2. Replies: 2
    Last Post: 07-18-2005, 11:37 PM
  3. Replies: 7
    Last Post: 02-07-2005, 07:35 PM
