Wow, your realy setting the way back machine. I don't think I've seen any of that equipment for almost 10 years! Good luck!
try to find some used soundstream reference amps. thats one of the ones i'd be considering if i were in the market for another amp
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
Just curious scott whats the Phaze TD1500 got a link?
SS Reference Amp 1
Thats only 50x4 though...
SS Tarantula
85x4 I dont know if I feel the look on it though... Its not the reference but is it any good?
SS Reference
Probablly the one that you were talking about?
Thats what I see at the moment.
yup :-) but good equipment is good equipment. you can't argue that the old ss reference amps weren't great performers.
Phaze is no longer around. Butler audio designed tube hybrid amps for phaze audio a few years later PPI bought out phaze and use the bk's design for a while then they sold out and made a cheaper version with hard to come by parts.
Butler Audio is still around and he's still making the tubedrivers but an updated version from the one i have. He calls them tubedriver blue. The nice thing about the old tubedrivers are that they utilize a balanced input ensuring a clean signal all the way from the pc to amp.
http://www.butleraudio.com/car.php
thats itSS Reference Amp 1
this was after ss stopped making amps in america, i believe they are made in china now with lesser quality componentsSS Tarantula
that's a great one. and will give you plenty of headroomSS Reference
another amp that i owned and would also recommend w/o hesitation is the xtant amps from a few years back (am i showing my age now?)
I had an 603x (you can see it in my install thread from my link) it sounded amazing! i really love that amp. I was perfectly happy with it (until i heard the tubedrivers)
M10k
My Car Pc Install
My Boat Pc worklog
What do you think bout the midbass stuff scott? Im guessin the tweed will be good for 2 way but I dunno what would be better if I went 3 way in the future? Tweed or fiberglass...
i say f/g if you can get your hands on them. They are supposed to be friendlier to tune for the first time diy'er. don't worry about the future because; with the diy community, you can always sell them down the road when you want to experiment with another setup. IF you were going to go to a 3 way in the future you could always try to squeeze in an 8" driver since you don't have to ask it to play as high up.
M10k
My Car Pc Install
My Boat Pc worklog
M10k
My Car Pc Install
My Boat Pc worklog
Is 50x4 going to be enough for all of this or do I not need at least 75x4 and up?
M10k
My Car Pc Install
My Boat Pc worklog
look for an efficient amp (80%+) and wooferst that are 87bd+ efficent and you should be fine. An even better option would be to get a high-output amp where you can turn the gains all the way down and still get the needed output. That way you'll be able to eliminate the noisefoor as much as possible as that again will improve sound-quality. And if you want to go for it all the way: Get a line-driver, so you can boost the output voltage on your source, and again, turn the gains down to a miimum or even 0.....
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
