Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 86
Thread: System Choices and Questions
  1. #41
    Nov 2006
    If I was to go with either of the RNX mids would 50x4 be enough for the amp or do I need the 75? Thats probablly a better way to word it lol...
    EDIT: Would the Monitor 1 MK4.70 be a good match for me? Only 150 and its supposedly 70x4
  2. #42
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Those are good amps-made by the same company that made arc audio amps.
    50X4 will work, but like scott said, around 75 is better, it really depends on how hard you plan on pushing them or the volume at which you want to play them at. A more ideal setup IMO is 100X2 for the mids and 50X2 for the tweeters since they are more efficient, they need less power.
  3. #43
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    also a large factor is how quiet your car is. 50wpc would force me to turn the dial to '11', even 75 wpc would get drown out at highway speeds (this was before when i had the components and passive x-over) my car is anything but quiet though
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  4. #44
    Nov 2006
    Yah... my truck is loud... V8 5.9L dual exhaust... hmmm... The guy said it was 70x4 @ 4 ohms for the MK4.70... Ill look into the 100x2 and 50x2 but I dont think theres enough space in the quad cab. Unfortunately I doubt I can put anything behind my rear seat because when it folds up the back seat hits the wall...
    EDIT: Should I get the MK4.70 if it really is 70x4 @ 4 ohms or should I get 2 seperate amps to power each?
  5. #45
    Sep 2006
    How much room do you have? budget?
  6. #46
    Nov 2006
    Preferablly under 200.. tops 250... room I dont have off the top of the head.... but essentially under the seats of my front and passenger sides... I cant measure either its raining...
    The 2 seperate amps would probablly be better then one big *** amp... now that I think about it lol...
    Still gotta get an amp for my subs too... Im laggin behind on this project lol
  7. #47
    Sep 2006
    so probably not much space under the seats and your budget includes the amp for the sub or just the amp for the fronts?
    I found some good ones right within your budget and power requirements, but I don't know where you would put your sub amp
    PPI sendonas
    or
    PPI PCX series
    If I come across anything I'll let you know.
  8. #48
    Dec 2004
    Los Angeles Ca
    this single amp could power your whole system:
    http://www.edesignaudio.com/edv2/pro...roducts_id=550
    if you break it down to $250 for the amp sub and $250 for the tweeter/mid subs then you would be right in your pricerange....it's long amp though so you'd have to get creative with the placement.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  9. #49
    Nov 2006
    I got room sorta in my sub box... Theres 3 compartments in my sub box 1 for each sub and one big one for an amp... Hopefully its big enough.
    I__I_______I__I kinda like that... lol ****ty but hopefully you get the idea.
    So those PPIs will be better then getting the MK4.70? For front stage...
    As far as the sub amp goes I wanna spend 150-200 on it or less always better.
    The Nine.5 only gives 600W at 2 ohms that would kinda be underpowerin the Assasins wouldnt it... Ill consider it as an option though....
  10. #50
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    If your sub's efficiency is high enough, power doesn't mean anything (goes for pretty much all speakers actually). Ofcourse overpower gives you more options, but underpower isn't per se bad.
    My system ath the moment:
    amp: 2x120watts
    sub: 1x120watts
    kicks: 80watt each
    tweeters: 70watt each
    All running in tri-mode of the same 2x120watt amp.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  1. Tachometer questions.
    By nricciar in forum Hardware Development
    Last Post: 06-30-2011, 05:08 AM
  2. TM-868 Questions
    By gadgetbuilder in forum Input Devices
    Last Post: 06-19-2006, 10:15 PM
  3. Replies: 6
    Last Post: 01-28-2005, 11:37 AM
  4. Power supply questions
    By miztahsparklez in forum Power Supplies
    Last Post: 01-24-2005, 12:13 PM
  5. Replies: 9
    Last Post: 10-07-2003, 09:19 AM
