Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 86
Thread: System Choices and Questions
  1. #51
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by BoondockSaints View Post
    I got room sorta in my sub box... Theres 3 compartments in my sub box 1 for each sub and one big one for an amp... Hopefully its big enough.
    I__I_______I__I kinda like that... lol ****ty but hopefully you get the idea.
    So those PPIs will be better then getting the MK4.70? For front stage...
    As far as the sub amp goes I wanna spend 150-200 on it or less always better.
    The Nine.5 only gives 600W at 2 ohms that would kinda be underpowerin the Assasins wouldnt it... Ill consider it as an option though....
    the assasins are only 8" subs. 300watts each (600 total) would be plenty.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #52
    Nov 2006
    Well I dunno if I wanna drop 500 on the nine.5 ... between the PPIs and MK what would be my best choice for front stage at least. I think they are my best bets if any...
  3. #53
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Hmmmmm And I'd step off from that sub actually...... Unless you have a compo that'll get to about 35Hz.... The 8" assassin only has an Fs of 38Hz, which means, if you really want sub bass, you should be able to tune UNDER the Fs. In this case pretty much impossible, unless you go with a 3-way frontstage.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  4. #54
    Nov 2006
    The assasin has a Fs of 46.8 Hz or somethin liek that... http://web.archive.org/web/200605020...html#enclosure
    That still not gonna cut it?
    EDIT: If I go with the ER18RNX they are 45-3000 Hz that would work right?
  5. #55
    Jun 2006
    Abele, Belgium
    should work. Although I would like to know the Fs of said driver to be sure. Cause some manufacturers tend to go under the Fs of the driver with given frequency-range. ANd playing over (on top) of the Fs is never a good idea, unless you can get the exact frequency EQ'ed out.
    CLARION HX-D2
  6. #56
    Nov 2006
    I doubt I can find out the exact Fs especially since I have no amp for it lol...
  7. #57
    Jun 2006
    Abele, Belgium
    the Fs of a speaker has nothing to do with the amp. It should be in the spec-sheets of said driver.
    CLARION HX-D2
  8. #58
    Nov 2006
    I got em used and it didnt come with any...
  9. #59
    Jun 2006
    Abele, Belgium
    you gotta love But I did a search for you and the Fs is 37Hz, so you should be fine.
    CLARION HX-D2
  10. #60
    Nov 2006
    Ok so now should I get the 2 amps or the 1 amp lol... Big question is will the single be good enough or is the 2 what it needs, or what sounds better I dunno Im not talkin straight...
  1. Tachometer questions.
    By nricciar in forum Hardware Development
    Last Post: 06-30-2011, 05:08 AM
  2. TM-868 Questions
    By gadgetbuilder in forum Input Devices
    Last Post: 06-19-2006, 10:15 PM
  3. Replies: 6
    Last Post: 01-28-2005, 11:37 AM
  4. Power supply questions
    By miztahsparklez in forum Power Supplies
    Last Post: 01-24-2005, 12:13 PM
  5. Replies: 9
    Last Post: 10-07-2003, 09:19 AM
