Page 1 of 9 123456789 LastLast
Results 1 to 10 of 86
Thread: System Choices and Questions
    Nov 2006
    Alright so Im finally buying the system, so far I have bought/ordered an Eclipse CD7100, Crystal SSCS6 6.5" Comp set, and 2 8" AA Assasins.
    Now I need to make some decisions, and buy my amps as well as deadner and wiring...
    First thing I guess I need to decide on is do I want to go active or passive. Im not quite sure what I would gain from doing either, but I know I can do both wtih my HU and my comp set. If anyone can fill me in on the advantages of going active that would be great.
    Next is should I purchase any more speakers (midrange/midbass) or tweeters? First off does the tweeter that comes with the Crystals do its job and do it well? Sound good and stuff like that or would I be better off buying some new tweeters? Or do I need to buy a midrange speaker?
    Also if I go active should I still be giving each speaker 150W? My understanding was in a passive set up each speaker recieves 150W so it would be the same in the active. I may be wrong though.
    Then for the amps for my sub the first two I was considering was the Cadence ZRS8 - had at around 175 and then the Lanzar Opti1400D - had at about 200... The Lanzar will probablly provide me with more power but the Cadence will provide me with a warranty. Just curious which way yall would go here or what amp you would put here in its place.
    Then my amps for the comps... if I go active I need an amp that can do 150x4 @ 4 ohms I believe I found a Cadence amp thats 180 that can do this... the TXA-6004. Im looking to spend less than 200 here so if yall have any other suggestions here I am open to them. And if I was to buy a 4 channel amp could I just use 2 channels and leave the other 2 channels open if I decided to go passive, at least temporarily? Or is this rediculousy unsafe or something?
    And I think thats it for now, unless someone wants to give me a list of all the wires I will need for this so I can order those now lol... But any help is appreciated thank you!
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    the biggest difference between active and passive is where the crossing over takes place. active cross's over at the signal level, meaning before the amp with RCA's. passive cross's over at line level, meaning the speaker wire, after amps.
    if you go active and have 2 woofers and 2 tweeters then you need 4 channels. passive would need only two.
    Theres plenty of info on this, go read up a lil
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    IMO, if you know how or are willing to learn how to tune it, and have enough amplifier channels, then active is the way to go. Passive sets are never designed with each car they are going into in mind, so they are set for a safe more generalized setup. In an active setup, you can correct for frequency and phasing abnormalities due to the environment.
    Regarding power, tweeters typically cannot handle the same power thermally that your midbass/woofers can handle. The passive crossovers sometimes have them attenuated and protected. IF you set your gains correctly, then your tweeters will be fine, but running the full 150W to them will probably shorten their lifespan.
    I can't tell you what amps to buy, so if one fits your needs better than the other go with that one.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    if you're going active; personally, i'd return the comp sets and go with some raw drivers
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Nov 2004
    NY
    Also, if you go active, you have more room for expansion later on for things such as "time alignment". Which will let you slow down some speakers, so all of them hit you at the same time. This gives things a much fuller sound... and is kinda cool when you think about it.
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
    Nov 2006
    Alright well that sounds good, im thinking active is the way to go now... this is all really helping thanks alot. And scott what do you mean by raw woofers? Like peicing together my own tweetwers and midbass?
    Also whats gonna be the difference between midbass and midrange? Should I have both?
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    I'd sugest you read up un the difference in drivers before, as scott said, picking "raw drivers" by which he means separate drivers, no filters or anything, just the speakers by themselves.
    The difference between midrange and midwoofer = A midrange is designed to only have a fluid curve at the mid frequencies, where a midbass will also take some of the lower frequencies. You should be fine picking a midbass and a tweeter and just go 2-way active. However, you could also go 3-way and pick more specific speakers for a certain range. But keep in mind a 3-way setup will be much harder to setup, put the x-over points right, putting your speakers by themselves at the right angle to get your frontstage right and eliminate phase problems and such......
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Nov 2006
    So if I was to do raw drivers, with a 3 way active system I would need 6 channels of power right? And about how much would the raw drivers come out to for a good system?
    Jun 2006
    Abele, Belgium
    Why do you wanna go 3-way immediatly? It's way harder to set up. If I were you I'd experiment with a 2-way setup first. You can easily be ready for $100-$200 for a 2-way setup. The cost will be finding amps that sound right and have the right filtering possibilities. Cause when you go full active, you can't stay behind with crappy amps.
    CLARION HX-D2
    Dec 2004
    Los Angeles Ca
    exactly, go two way and you'll have better results (that's what i'm doing)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. Tachometer questions.
    By nricciar in forum Hardware Development
    Last Post: 06-30-2011, 05:08 AM
  2. TM-868 Questions
    By gadgetbuilder in forum Input Devices
    Last Post: 06-19-2006, 10:15 PM
  3. Replies: 6
    Last Post: 01-28-2005, 11:37 AM
  4. Power supply questions
    By miztahsparklez in forum Power Supplies
    Last Post: 01-24-2005, 12:13 PM
  5. Replies: 9
    Last Post: 10-07-2003, 09:19 AM
