Results 1 to 4 of 4
Thread: Durwood, Red.... Anyone... What Software To Use With my Soundcard?
    Variable Bitrate Area3's Avatar
    Mar 2007
    The Colony , Texas
    Well I use this when I Dj....
    NI brings audiophile quality to USB interfaces!
    With AUDIO KONTROL 1, Native Instruments provides an audiophile-quality interface. AUDIO KONTROL 1 is a high-end audio interface offering crystal-clear 192 kHz, 24 bit-quality. It is far more than just a sound card. Freely-assignable buttons and controller knob combined with advanced MIDI and key command functionality grant full control of software applications - setup files for popular programs ensure it's hassle-free. AUDIO KONTROL 1 merges innovation and quality and does so with an ear for practicality. AUDIO KONTROL 1's is very adapatable making it the perfect audio interface for musicians, producers and DJs. Versatile connection configurations, included controller assignment preset files as well as the full versions of XPRESS KEYBOARDS, GUITAR COMBOS, and TRAKTOR 3 LE also expands AUDIO KONTROL 1's functionality.
    Native Instruments AUDIO KONTROL 1 Features:
    * USB 2.0 Interface
    * 24-bit/192 kHz quality
    * Cirrus Logic A/D, D/A converters
    * 103 dB-A SNR
    * 2 balanced inputs: 1 line/mic (XLR/1/4" TRS Neutrik, phantom power supplied) and 1 line/HiZ (TRS)
    * Individual gain controls with acitvity and clip LEDs
    * 4 balanced outputs (1/4" TRS ) with two stereo level controls
    * Headphone output with A/B source switching and level control
    * Direct monitoring with mono switch and mix control
    * Low latency ASIO/Core Audio driver
    * USB 2 bus powered, MIDI I/O
    * 3 freely-assignable buttons and 1 controller knob
    * MIDI and key commands support for control of professional audio software and other media applications such as iTunes, Winamp or Final Cut Pro
    * Includes full versions of TRAKTOR 3 LE, GUITAR COMBOS and XPRESS KEYBOARDS
    * ASIO, Core Audio, DirectSound
    * Mac OSX 10.4.x, G4 1.4 GHz, 512 MB RAM Win XP, Pentium/Athlon 1.4 GHz, 512 MB RAM
    * Windows systems must have Service Pack 2 installed
    Ok Now the Question...
    I want to Be Able to Use the Buttons and knob In my Front End And..
    I Am Also Looking for FULL 31 EQ With Limiting and Assignable Outputs... I dont need Crossovers.
    Does Such Software Exist?
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    You probably won't be able to interface with any of your buttons on the actual card via the front end unless you can configure Girder to do so. I have never played with girder so I can't say yes or no.
    If you are using a frontend such as roadrunner that utilizes winamp, then you can get the vst plugin bridge (also a wiki article explaining how to do that) then you can load an EQ from within the vst bridge, look for EQ vst plugins. There are a few listed in the mp3car wiki pages under audio tuning.
    http://www.mp3car.com/wiki/index.php..._inside_Winamp
    http://www.mp3car.com/wiki/index.php...g_via_Software
    I can't tell you which EQ does compression limiting so you will have to look for yourself. There are literally all sorts of VST EQ's available. We have only linked a few of the more popular ones and or free ones.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    fusion brain and a soldering gun may get you pc control of that device
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2007
    The Colony , Texas
    Btw The Front End Will be Centerfuse
    I have Kinda Sorta Figured Out How to use the knob and the Buttons...
    Now I just need to Figure out how to conrol EVERY Little DARN thing in my Sound System
    Thanks - Eric Scott
    Area 3 Productions
  1. New system - What software do you all use... what should I put on mine?
    By dsj1979 in forum Software & Software Development
    Last Post: 11-19-2006, 04:16 PM
  2. AutoTap used to develop custom software!
    By Dodger1417 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-25-2006, 11:51 AM
  3. Replies: 27
    Last Post: 09-23-2006, 06:55 PM
  4. comparison of GPS Software
    By gunsandrosses in forum Newbie
    Last Post: 06-28-2006, 10:56 PM
  5. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
