Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: how much difference if I replace a 10" with a 12" sub
    May 2006
    So, I have two 10" subs in the rear dash.. being pushed by a 400 W amp. I was considering replacing just one with a 12" sub of the same make... essentially to get a little deeper sub bass ... i still want the nice punchy mid range 10" but if I'm running the exact same signal / eq to both, will swapping the 10" for a 12" make a noticeable difference ?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i wouldn't mix and match. i'd look into getting a better sub rather then changing one out. either a 10 that can hit lower or a nice 12 that is tight. what sub do you have?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    May 2006
    10" Infinity subs...
    Dec 2004
    Los Angeles Ca
    are they in the correct sized enclosure? try adding some poly fill to simulate a larger box
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    ya, don't mix them, at least not on the same amp.
    Try what scott_fx said, either rebuild the box, or add poly fill to the one you have.
    Mixed systems usually have a pair of tens, and a pair of twelves, (or pair of 12s, and pair of 15s.) This gives you a little better symmetry, not only in looks but in sound too. This is harder to tune though.
    If it were my car, I'd replace both 10s with 12s, and get some good mid bass drivers for the front. Some 8's maybe, and use a seperate amp to drive them. My infinity 12s still give me good punch from drum kicks, and deep rolling bass from synthesizers and bass guitars. So you may not even need the mid bass if you don't want.
    It's mostly about the box it's in. The 12s need 1.25 cu ft or air space, and the 10s only need about 0.75 cu ft. If you put the 12s in the box the 10s were in, the sub would be "choked" and not perform like you'd want, or they may even damage the subs. On the other hand, the 10s may give you more bass just by increasing the volume of the box to maybe 1.0 cu ft.
    here's the spec sheet for the infinity 1052W:
    http://manuals.harman.com/INF/CAR/Bo...ters/1052W.pdf
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Mar 2006
    10 inch subs = quicker harder hitting base, basically good response
    12 inch subs = deeper frequencies and louder at those deep frequencies but slower response
    basically what type of music do you listen to?
    as the others stated DON'T mix on the same amp. Switch them both or put them on different amps.
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Cinfraco View Post
    oh no.. not this argument
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2007
    Lakehood, CO
    Quote Originally Posted by scott_fx View Post
    I agree, let's squash this early.
    It all depends on the subs, the box, the amp, the car, etc. Use what you like, if you are happy with your 10's then keep them, if you are happy with your 12's then keep them, if you don't like what you have (like the OP) then change one of the above (amp, box, both subs) until you personally like what you have.
    So please, don't anyone debate which is better or sounds better, etc. The OP was wanting to know if he'll hear a difference if he switched, not what the advantages and disadvatanges between the two sizes are. (Since they are so varied between different brand and models, it's impossible to come to a resolute conclusion)
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    May 2006
    yah.. I just wanted to know if I'll get a little more subby bottom if replaced the one 10" with a 12" using the same signal already being sent to the other ten...
    Dec 2004
    Los Angeles Ca
    play with the box size and/or poly stuffing and see if you're happy with the results. poly fill will be a great start and it'll only cost you a couple bucks
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. subwoofer comparison: 10" & 12"
    By johnnm in forum Car Audio
    Last Post: 03-13-2006, 03:03 PM
  2. Help match me a 10" or 12" sub to my amp please!
    By tbird2340 in forum Car Audio
    Last Post: 07-21-2005, 08:07 AM
  3. FS: 10" 12" subs, ITPS, PW-200-M +more
    By WebDog in forum Classified Archive
    Last Post: 02-14-2005, 12:09 AM
  4. 10" or 12" touchscreen
    By daveyfl in forum LCD/Display
    Last Post: 07-06-2004, 09:43 AM
  5. EBAY FS: 12" LCD, 10" LCD, Other Sttuff
    By lifeboat in forum Classified Archive
    Last Post: 04-14-2004, 11:03 PM
