Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Windows has multiple levels of volume controls. How to set properly?
  1. #11
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    That is a good question that I don't have an answer to. Does centrafuse use the windows kmixer still to change volume or can volume adjustment be performed directly in DirectX? Maybe ask the developer or specifically in his forum. Or do some research on DirectX.
  2. #12
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    The Media Player is the exact reason i am not using Centrafuse, i really like the software though..
    The way I understood Centrafuse is adjusting the windows master volume remotely...
    That and the lack of support for FLAC files did it in for my frontend.
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  3. #13
    Oct 2006
    So leaving WAV and master volume at 100% and using winamp if needed to adjust output level is a good (simple) choice.
    Bypassing kmixer with some type of kernel streaming plugin to winamp is a better sound quality choice (but more complicated install/configure/troubleshoot & may require resampling media files to 24-bit?).
    Can someone expand on this a little?
  1. Replies: 6
    Last Post: 11-28-2006, 01:23 AM
  2. Control multiple volume levels
    By Splinter in forum Road Runner
    Last Post: 10-12-2005, 11:37 AM
  3. How to set Freedrive directions volume
    By Phythorian in forum Road Runner
    Last Post: 07-28-2005, 06:35 AM
  4. Does software like this exist? Touchscreen-friendly Volume & Mute Controls
    By azzurro in forum Software & Software Development
    Last Post: 05-07-2005, 12:35 PM
  5. Replies: 0
    Last Post: 11-04-2004, 06:46 PM
