Unfortunatly, your dealer was right. The output on your headphones-out is really low.... Not that much you can do here.
I have an "Auxillary" input into the head unit of my car which was sold and installed by the dealer. I use for a Creative Vision M 30G MP3 player. With the output of the MP3 player turned to max and the HU input level set to max the system output is still low. Quite a bit less than the sound level when I switch FM or CD as the source. I showed this to the Dealer and the response was, it works at all, be happy. It's not our fault that the output level of your MP3 player is too low. (The mfg later added a preamplification to the HU.)
I would like to add a 12VDC powered preamplifier\linedriver to boost the signal.
I would appreciate recommendations of preamplifiers\linedriver you have used or heard installed in a car that worked well. Looking for units with good gain (15 to 30dB), low noise (S/N > 90dB), and does not seem prone to interference problems.
Something under $30 would be cool too.
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
look at dave navone's website and look for a linedriver. you dont need a preamp (that has a volume knob)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
forgot about that (eventhough I'm probably gonna need one myself
CLARION HX-D2
Phoenix Gold makes a 2 channel line driver fairly inexpensive. Memphis audio, audiocontrol are a couple others.
System always under construction
M10k
My Car Pc Install
My Boat Pc worklog
