I dont believe that device works in that direction. I'm not too familar with that particular device but it looks to be a 4 ch line out converter. It takes the factory speaker level lines as an input and makes the signal adjustible so that the low RCA level output can be used to be input to a factory or aftermarket amplifier. You cannot use that device to send the low level signal from the computer to the speakers, and it will require an amplifier.
LinkBack URL
About LinkBacks
