Results 1 to 10 of 11
Thread: New radio installed in tahoem audio problems
    Aug 2007
    i installed a jensen vm9312 in my 2001 chevy tahoe everything seemed to be working fine but there was no audio. so i hooked up factory radio up and it worked fine. what i found was a second wire harness which seemed to be for the onstar created this problem. i searched around and found that i need an adapter for the onstar. my question is do i really need this? i dont care about onstar at all. these adapters are really expensive, is there a short cut around this?
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    what soundcard are you using?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Does he have a CarPC? I think not.
    Thantos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Aug 2007
    no i do not, reason why im asking here now is because this is my first step before i step into a car pc
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i installed a hard drive radio in my sisters tahoe...the second harness has one wire that seems to be the "remote" wire for the factory amp. I just ran the remote wire from the radio and tested each wire( on the second harness) until the sound came on and just tap it.
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Aug 2007
    Quote Originally Posted by EsKALad View Post
    so is the factory amp not getting power? if so how much power does it need?
    Jan 2005
    Chicago, IL
    it just needs the remote wire like a aftermarket amp. its powered up through the batter but needs the remote trigger to know when to turn on and off.
    Aug 2007
    any idea which one this would be, on my jensen its blue, perhaps same colors? btw thanks for the help
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by thanatos106 View Post
    Thantos.
    yeah.. i was just being an ***
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    chicago, Illinois
    Its usually a pink wire in the 2nd harness.
    PROGRESS:
  1. Audio quality problems
    By Etho in forum Car Audio
    Last Post: 12-04-2006, 09:07 PM
  2. Problems with audio equipment
    By tech55 in forum Car Audio
    Last Post: 02-19-2006, 05:56 AM
  3. Computer audio output thru radio
    By Pokey in forum Car Audio
    Last Post: 05-25-2004, 04:49 AM
  4. Audio problems
    By Rocker298 in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:49 PM
  5. Having problems running audio from my Shuttle to my amp
    By 0din in forum General Hardware Discussion
    Last Post: 06-19-2003, 02:41 AM
