Results 1 to 4 of 4
Thread: Possible ground problem with my antenna?
    Feb 2007
    Richmond Virginia
    I have installed my carpc into my 2004 Dodge Ram. I have a pioneer head unit that is connected to my SB x-fi soundcard. I can play cd's w/o any noise issue but as soon as I try to listen to my radio I get poor reception. I live in a rural area and before I put in my carpc my stock HU got good reception on about 4 stations. Now I can get only 1. If I use an antenna extension and connect my current Pioneer HU to my Mazda Miata I get perfect reception on 5 stations and no static. Any suggestions? I have done nothing to my stock Dodge antenna since putting in the carpc.
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    Did you run power to the antenna lead? That would be my guess.
    Aron
    Absolutely 100% stock
    Feb 2007
    Richmond Virginia
    No my antenna is not powered. I think I'll try to reverse this and see how my miata radio works with the dodge antenna by connecting it with my 12 ft extension cable. Could it be my antenna is bad?
    Jun 2006
    Chicago, IL
    Make sure you ground everything(computer case, antenna assembly, power supply) very well, I had same problem, and follower Gizmo's advice, now it works just fine, no noise on FM.
    EPIA TC 1G 256MB 60GB Linux,WindowMaker, Roadnav, Xine, XMMS, iGuidance3
    Lilliput 8", Pharos i360, WUSB11v2.6 WiFi
  1. Calling all XM experts... 2 antenna wires vs. 1
    By Nola111 in forum Car Audio
    Last Post: 03-10-2009, 08:13 AM
  2. How to ground a macmini for carputer?
    By cyruslow in forum MacCar
    Last Post: 04-03-2007, 01:21 PM
  3. Ground loop isolation problem
    By AceRimmer in forum General Hardware Discussion
    Last Post: 04-01-2006, 04:00 AM
  4. holux 210 gps antenna problem Help please
    By professorjason in forum GPS
    Last Post: 09-04-2005, 01:38 PM
  5. Question Regarding Power Antenna
    By temposs in forum Newbie
    Last Post: 11-13-2004, 08:14 PM
