Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Home Theater Subwoofer
    Newbie l33t_tj's Avatar
    Aug 2007
    Texas
    Can i use a home theater subwoofer in my car?
    It plugs into the wall and i have a power inverter that can handle it. It has input for left/right and an RCA plug on the back.
    I don't know if it will blow anything if i put it in my trunk?
    P.S. i have a 93 chrysler lebaron with stock stereo.<br /><br />
    FLAC is for flaccid parksgm's Avatar
    Dec 2005
    Dallas, Texas
    You can likely use it with the inverter, although it probably won't sound good as the speaker was designed for a much larger environment, and you'll likely have noise/grounding issues related to the inverter that may make it effectively unusable.
    Worth a shot, though, if that's all you have and you don't want to spend any money.
    Aug 2007
    Ask checksum
    Newbie paragraph's Avatar
    Aug 2007
    Friggin' New Joysee! Sirius Station: 27 HardAttack
    Quote Originally Posted by mr_cool View Post
    Ask checksum
    haha... -_-
    you sure as shoot can use it
    i don't know how well it will sound, but you definitly can use it.
    just make sure you wire it up into the right channel, that ususally will bive you the best mono sound.
    However, if you have the stock stereo there might not be a sub-out, so you'd have to ask someone else how you'd wire it up.
    '93 Camry - Work Log
    Progress (Slow and Steady)
    Phase 1: Planning and Software Procurement
    Total Cost So Far: $75
    Free Laptop Parts (DVD ROM!)
    Aug 2007
    Texas
    Ok, thanks!
    Jun 2005
    chicago, Illinois
    The only problem, besides what has already been mentioned, is if you were to use this as stated with the inverter. How are you going to turn it on or off? Car amplifiers are activated via a remote turn on wire. And I believe that Self-power home theater subs are signal sense activation, but they are always on. And in this case, so will your inverter.
    PROGRESS:
    Feb 2007
    Pittsburgh
    Quote Originally Posted by pancit175 View Post
    a relay
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Quote Originally Posted by Cutrara View Post
    a relay
    either that or wire the inverter to an ignition wire so that it turns off when the car is off. Just make sure its fused/gauged properly.
    Live mp3Car Facebook Chat
    Jun 2005
    chicago, Illinois
    The only problem with a relay or wiring up to the ign is depent on how much current is required to run the Inverter. Potentially a standard bosche relay is only capable of giving up to 30A which equates to only about 4200W@14Vdc or 360@12Vdc. If the inverter requires more juice then multiple relays or higher amperage relays may be required.
    PROGRESS:
    Dec 2005
    Dallas, Texas
    I doubt that his home theater sub draws more than 500 watts or so...usually those home theater sub/amp combos are not "highly powered" compared with car equipment.
    If it does, then simply use two relays.
  1. Subwoofer Phase
    By IDOXLR8 in forum Car Audio
    Last Post: 10-27-2006, 11:34 PM
  2. Is my subwoofer amp pooched?
    By WoLLy in forum Car Audio
    Last Post: 04-01-2006, 10:16 PM
  3. subwoofer grounding problem
    By megagoo in forum General Hardware Discussion
    Last Post: 12-23-2005, 11:41 PM
  4. Replies: 2
    Last Post: 10-08-2005, 03:01 PM
  5. Replies: 4
    Last Post: 09-19-2005, 06:41 AM
