I would try the audio from your onboard sound and see if it is acceptable to you. If it is, then you've saved a good-sized chunk of change by not buying a high-end sound card.
If you're only using 4-channel sound, then 5.1 is a moot point, really. You simply need 4-channel audio, which can be done with just about any sound card.
LinkBack URL
About LinkBacks
