Results 1 to 7 of 7
Thread: crossover question
    Aug 2007
    crossover question
    hi i bought Infinity component system REF 6010 CS
    and it came with Crossovers. i never did a car audio before. for those Speakers i also bought Kenwood KAC-6402 4-Channel Amplifier. this is my Cross over
    my question is that stock speaker wires coming from head unit do i add them to the cross over or i have to run those back to amp and then from amp to cross over? also my Car had Tweeters and there was no cross over for it. i hope u guys get it what i am saying it. if not let me no ill explain it again thx.<br /><br />
    Aug 2007
    come one some on e help me out plz
    May 2006
    Belgium
    If u'r using just using your headunit, then you need to run the wires comming from your hu to the crossover. if you'r using an amp, then you should run wires from your amp to the crossover.
    your car had tweeters before, and there was some sort of crossover . look at the tweeter closely, there is somethink (i think a capacitator) soldered on to it. that's what does the crossovering...
    Greetz
    Dj NRG
    Aug 2007
    emm the wiring for the tweeter is in Harness also so i don't have to connect the old wires to the cross over so i will get the sound from head unit to amp in rca wire then from amp to Cross over am i right.
    Dec 2006
    Jacksonville, FL
    rca to the amp, wire to the crossover. Connect wires to the speaker connection, connect mids to woofer, tweets to tweeter.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by malkamus View Post
    very simple and leave the stock wiring out of the whole equation
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Aug 2007
    Thx guys for the help
  1. Replies: 2
    Last Post: 05-02-2006, 05:15 PM
  2. crossover question
    By yonu in forum Car Audio
    Last Post: 07-21-2005, 09:50 PM
  3. crossover question
    Last Post: 06-11-2005, 04:06 PM
  4. Question about crossovers, etc.
    By jchahn in forum Car Audio
    Last Post: 06-09-2005, 05:36 PM
  5. FM Card Question....
    By Superbike1k in forum Car Audio
    Last Post: 05-16-2005, 09:03 AM
