Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Infill G4 in Hummer H3 - finaly done, But...
  1. #11
    Aug 2007
    Quote Originally Posted by amedesign View Post
    Dear haiminger,
    I have the same problem (same carPC, not the same car ) with the noise even the engine is not running. Please tell me how did you wired because the available wires are only the 4 speakers (6 ohm). Did you wired directly to the speakers? Is it this device proper for low resistance output because I have read that "SNI-35 converts 2 to 40 watts per channel speaker level output into a pre-amp signal. Perfect when adding an amplifier to a factory or aftermarket radio. Great for getting an additional set of pre-amps outputs from a head unit equipped with only one set."
    thank you very much for the answer.
    Hi There,
    The thing is in my type of car there is a pre-amp installed in the factory, So the problem was that the G4 had high signal output, while the Pre-Amp expected a low signal Input. The G4 is not connectted directly to the speakers in a Hummer, It allways via the Pre-Amp, so the PAC SNI-35 was the only thing that solved the problem for the G4 and my Hummer. I'm not sure it's the best solution for any other car also.
  2. #12
    Feb 2008
    Quote Originally Posted by haiminger View Post
    Hi There,
    The thing is in my type of car there is a pre-amp installed in the factory, So the problem was that the G4 had high signal output, while the Pre-Amp expected a low signal Input. The G4 is not connectted directly to the speakers in a Hummer,...
    Thank you very much for this answer. I was afraid about this!
  1. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  2. G4 with Infill Station
    By flapster in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 01-10-2008, 08:27 AM
  3. CF 1.2 on Infill G4
    By SUNAJ in forum Centrafuse
    Last Post: 08-21-2007, 07:38 AM
  4. Replies: 7
    Last Post: 08-13-2007, 07:15 PM
  5. How to Power an Infill G4 Unit using an ATX PSU
    By snakeye5 in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-20-2007, 07:52 PM
