Page 1 of 12 1234567891011 ... LastLast
Results 1 to 10 of 112
Thread: Amplifier behind dash / kit amp ?
    Aug 2006
    Hi all,
    New car pc project underway since I've just changed cars... I'm planning to fit a 7" screen into a custom double din fascia so I don't have to cut up the dash at all. To go with this I'm going to need an amp as I'll have no where for the stereo to go...
    Can anyone suggest something that I can fit behind the dash for an amp? I am just running std speakers and ideally want the smallest amp possible.
    The sort of thing I am looking for is an amp that I can power from the ISO connector so I don't have to run extra cables etc.. and hopefully I can mount it in the double din sized void behind the touchscreen.
    So far I am considering a Mondeo amp (not sure how big these are) or some sort of Velleman style kit.. (not sure which I need)
    Any suggestions would be appreciated.
    Jun 2005
    chicago, Illinois
    To barrow from another member:
    Quote Originally Posted by scott_fx View Post
    if you want a small form factor amp check out the www.41hz.com or get a piar of sonic impact t-amps and wire them with a relay. the t-amp will put out about as much power as a stock head unit. the 41hz amps are more powerful (for the most part)
    PROGRESS:
    Newbie paragraph's Avatar
    Aug 2007
    Friggin' New Joysee! Sirius Station: 27 HardAttack
    yep, 41hz will be the best option for small+power.
    However, i'd re-check your options.
    a traditional amp will fit below the passenger seat without any effort, and a nice small 2 chan amp (like 300w) will take up very little room.
    edit: of course that means extra wires but if your dash is like mine there really isn't a lot of room.
    '93 Camry - Work Log
    Progress (Slow and Steady)
    Phase 1: Planning and Software Procurement
    Total Cost So Far: $75
    Free Laptop Parts (DVD ROM!)
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    david navone has a small 20 watt amp as well
    http://www.autosound2000.com/linedrivers.htm#20x20amp
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Aug 2006
    Thanks for the suggestions guys, I'd really like to keep it all up behind the dash if I can.
    The 41hz kits look really neat, could one of you knowledgable bods just confirm this would be ok to use in a car; http://www.41hz.com/main.aspx?pageID=130
    I presume I don't need anything extra.. just get the kit and build it ?
    Also would anyone know how warm this kit is likely to get, that is my one concern about putting something behind the dash.
    Thanks for the help!
    Nov 2006
    Huntsville, AL
    Hi Swift_Gti,
    I'm using an AMP32 kit in my carpc right now. You will need a heatsink as a bare minimum. Additionally, I'd suggest a regulated power supply of some sort. You don't want to spend all that time building the kit just to fry it in an overvoltage situation. My AMP32 is being powered from the 12v line of my M2-ATX along with my LCD, though my mobo is a low power embedded board, so I have the wattage to spare.
    My setup has the entire carpc in a gutted, OEM 2DIN chassis. I bought and assembled 2 of the AMP32's, but I am only using 1 at the moment. The OEM chassis has a large, cast aluminum backplate and I have the amp mounted to that for heatsinking with no problems so far.
    Another issue I had with the AMP32 was the BIOS POST beep. My BIOS beeps at the end of the POST routine no matter what. The beep is played through the built-in mobo speaker, but it is also played on the soundcard output at full volume. This means that if the amp is powered when the mobo boots, you get an ear shattering beep every time.
    The AMP32 has a mute jumper. Short the jumper and the amp is on. Disconnect the jumper and the amp is muted. As I recall, the jumper completes a circuit to one of the input pins on the IC. So feeding a standard 12v amp-on signal (like the M2-ATX provides) doesn't work so well. I ended up using a transistor wired to the serial port DSR line and the amp jumper. Using the AmpCtrl service (do a search here), the amp stays muted until the OS fully boots. No more deafening beep.
    My car is a 92 Miata (wife won't let me gut the '02) and I normally drive around with the top down. I'm only using 1 AMP32 because my mobo only has 2 channel audio. That said, the AMP32 has more than enough power to get the job done. The volume control has never gone above 50% in my car, even at 70+mph with the top down.
    pb
    Aug 2006
    Wow, excellent info pbarrette - really useful stuff!
    I'd be very interested to learn more on exactly how you wire up the DSR to these amps.
    One thing.. may seem silly but amps aren't my strongpoint!
    I am using my std car speakers (1 pair of component speakers up front, 1 pair of component speakers in the rear..) what is the best amp to use?
    My audio feed is just a set of stereo RCA jacks (one red one white) do I need a 4 channel amp (like the Amp9) or will a 2 channel work (like the AMP32) - is there an advantage of using one over the other ?
    Thanks for the great info.
    Apr 2007
    St. Louis
    I built AMP9 and it doesn't get hot. You need heatsink, but it's not warming up with my usage. I'm planning on using it in my CarPC (dual DIN)
    Right now I use iPod as a source and power AMP9 from my Car's stereo jack (15A line)
    This chip designed for automotive use and fine with unregulated power.
    I have one extra 27V version that I can sell. It's tested and working.
    Apr 2007
    St. Louis
    Quote Originally Posted by swift_gti View Post
    You will need 4 amplified channels for 4 speakers. Since you have stock stereo - 2 AMP32s will do nicely for you. 25W per channel should be plenty. AMP9 gives 4 channels and have about 60W per channel on 12V and 4Ohm speakers. This is good to play more powerful components.
    I split each chanel to 2 inputs on AMP9 and then feed each speaker individually.
    Aug 2006
    Thanks for the info Katit, I'm planning to do the same thing in terms of wiring up power etc. Is there anything in the instructions that get sent through regarding current drain? I would imagine the existing wiring harness in the car is fine but I don't want to fry anything
    Thanks for the offer of the AMP9 kit, but I think I'm going to get the 12v version due to the lower profile.
    Cheers
  1. multi amp kit will this work?
    By ali7up in forum Car Audio
    Last Post: 02-07-2007, 06:38 PM
  2. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
  3. What's a good Amp Kit?
    By L-U-R-C-H in forum Car Audio
    Last Post: 09-04-2005, 10:05 PM
  4. Multi Amp Kit, Any Specific Bundles?
    By mattwz in forum Newbie
    Last Post: 06-15-2005, 08:50 PM
  5. 1/0 Gauge Amp Wiring Kit (Blue/Silver)
    By Xtreme2k2 in forum Classified Archive
    Last Post: 09-09-2004, 11:25 PM
