Results 1 to 3 of 3
Thread: sat radio antenna
    Newbie RAMRunnr's Avatar
    Jun 2007
    sat radio antenna
    Does anyone know if there is an aftermarket antenna similar to this <click> that work with Sirius sat radio, as well as GPS, Wi-fi, Cellular and PCS. I am wanting to install a Multi-in-one solution to reduce the clutter of antennas on my van. Right now I have a wi-fi, GPS sat, Sirius Sat, CB, radio scanner, AM/FM radio, and PCS antenna. That would remove four antennas, and I am getting an adaptor to run my scanner through my AM/FM antenna.
    I have done internet searches, but I am only finding the shark fin kits for FM antenna, or connecting/hacking into a factory antenna on cars, mostly BMWs.
    Thanks for any help you can give.
    1985 Chevy G20 Conversion van - VIA EPIA MII12000 in custom built case. Still a work in progress
    1996 Ford Mustang Cobra
    1997 Honda Del Sol
    Jun 2005
    chicago, Illinois
    The problem you might run into is the fact that the antennas run off of different frequencies. Sat Radio for example, in my experience i've seen other installers attempt to switch the units of xm for sirrius, or vice versa, without switching the antenna. Afterwards the unit does not get some channels when using the different antenna.
    PROGRESS:
    Jun 2007
    I have heard of the same problem. I was just wanting less clutter on my van, but I think I will get the antenna from the mp3car.com store and work with what I got. I will still be able to reduce with this antenna. We will see what happens.
    1997 Honda Del Sol
  1. FM Radio Antenna Help
    By dan8304 in forum Car Audio
    Last Post: 06-27-2006, 02:27 PM
  2. Can A Wireless Network Adapters Antenna Be used for GPS or Radio?
    By Lava in forum General Hardware Discussion
    Last Post: 06-13-2006, 06:32 PM
  3. Need urgent help to buy radio e antenna
    By Denun in forum General Hardware Discussion
    Last Post: 07-23-2004, 03:39 PM
  4. X-treme radio USB antenna conection
    By BOND007BE in forum General Hardware Discussion
    Last Post: 07-23-2004, 09:40 AM
  5. Using radio antenna for radio AND tv
    By pyros in forum General Hardware Discussion
    Last Post: 05-19-2004, 02:06 AM
