Hey guys,
I am in the process of gathering everything up to install my carpc. I already have my computer (see below for specs), wireless keyboard and Sirius satellite modification kit. What do you guys recommend me using to send an audio signal out? I was looking at the Turtle Beach Audio Advantage Roadie USB audio adapter but after doing more research I’m not sure it will work any better than their Audio Advantage micro. I would really like two sets of outputs (front and back). Does anyone have any recommendations on what I should use? I’m stuck.
(My audio system: (1) KX600.4 amp driving (4) 6x8 Kickers with 1” tweeters, (2) KX1200.1 amp driving (4) L5 Dual Voice Coil 12’s)
Enclosure
• Automotive grade PC enclosure
• Tough design with 5.5mm black anodized extruded aluminum
• Integrated case fan for proper cooling
• Four integrated mounting feet/tabs for installation onto any flat surface
Dimensions & Weight
• 8.4"(W) x 10.1"(D) x 2.25"(H)
• ~4lbs
Operating Temperature & Humidity
• -10 to 60 Degrees Celsius (14F-140F)
• Third party testing shows capable of -40C (-40F) cold starts.
• 0% ~ 93% (relative humidity; non-condensing)
Audio Subsystem
• VIA VT1617A 6 channel AC’97 Codec
• Full Duplex 3D Stereo Sound
Software AC '97 Audio CODEC
• 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
VGA & Video
Onboard Video, with full Motion Video Acceleration, Hardware MPEG2
• Motion Playback at 30 fps.
• Integrated VIA Unichrome AGP graphics
• MPEG-2 and MPEG-4 Decoding Accelerator
• Standard 15 Pin CRT Monitor Connector up to 1280x1024x24
• S-Video & Composite Video Output Connectors (NTSC/PAL)
Input & Output Ports
• (1) RJ-45 LAN port
• (1) PS2 mouse port
• (1) PS2 keyboard port
• (1) Serial port (external)
• (1) Serial port (internal)
• (2) USB 2.0 ports (external)
• (3) USB 2.0 ports (internal)
• (1) D-Sub 15 VGA port
• (1) RCA composite video port
• (1) S-Video port
• (1) 1394 Firewire port
• (3) Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
• (1) Molex wiring harness connector with power, ground, ignition hot.
LAN
• VIA VT6103CL 10/100 Base-T Ethernet
Operating System & Software
Windows XP™ Pro OS Pre-Loaded
• Digital Dash Car PC Software Front-End
CPU
• VIA C7™ 1.5ghz NanoBGA embedded processor
• 133mhz FSB
• Low power consumption (<15W)
RAM
• 1024mb (1gb) DDR2 533 RAM
Hard Disk
• 80gb 2.5" Mobile Laptop Drive
• 5400rpm rotational speed
• Mounted on rubber-shock absorbing dampers
• High non-operating shock tolerance by load / unload technology
• FDB (Fluid Dynamic Bearing) motor for ultra silent operation
• Vibration Operating 9.8m/s2 { 1.0G } (5 to 500Hz)
• Shock Operating 1,960m/s2 { 200G } 2ms
Optical Drive
• Optional Slim Slot Loading External Firewire DVD/RW+ Combo
System Board
• VIA CN700 North Bridge Chipset
• VIA VT8237RP South Bridge
• Embedded Motherboard
• Award 4 MB Flash ROM
• 240pin DD2 DIMM socket w/locking mechanism
• Wake-on-LAN
• Keyboard Power-on
• Timer Power-on
• System power management
• Power failure recovery
Power Supply
• Intelligent Vehicle Power Supply
• ATX, 6-24V wide input range
• Intelligent shutdown controller, powers on and off with ignition.
• ON/OFF motherboard control
• Survives vehicle engine cranks
• Battery deep discharge prevention
• High efficiency, 90 watts output
• Works with 12V / 24V car batteries
• "Anti-Thump" Amplifier remote control
• 10A automotive fuse (mini-blade)
Expansion Slots
• (1) PCMCIA Slot - CardBus Type I & Type II
• (1) Compact Flash Slot
