Results 1 to 4 of 4
Thread: Crossover producing votage on its own?!
    Variable Bitrate Tim Lake's Avatar
    Oct 2005
    Bedford, UK
    I suddenly started getting a rumbling from my subs even with no music. I disconnected the USB DAC (soundcard) but it continued. I pulled over and systematically disconnected things from the crossover. With no input it still did it but if I removed the outputs, it stops so it must be the crossover causing it. One of my components has now blown so I suspect the crossover isn't earthing and while the subs could take it, the components couldn't.
    Does this sound feasible?
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Bluetooth, 802.11g, GPS
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    NLited XP with Road Runner and MapMonkey
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Sounds like a either a bad RCA conenction or a bad ground. What brand was it anyways?
    Oct 2005
    Bedford, UK
    Quote Originally Posted by durwood View Post
    Pioneer! I wouldn't expect it from them. I'll double check the grounding, i've had no end of trouble with grounding generally
    VIA M10000
    512Mb RAM
    30Gb 2.5" HDD
    Silverstone USB DAC
    Consult (ODB)
    CarTFT K500
    Carnetix P1290
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Tim Lake View Post
    pioneer is actually notorious for floating ground issues on their head units, it doesn't surprise me. try to ground the outer sleeve of the rca's and see if that solves your problem
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  1. Can someone help with my questions about my install?
    By drew22mader in forum Car Audio
    Last Post: 03-11-2008, 10:14 PM
  2. Digital Crossover and EQ
    By spoonraker in forum Car Audio
    Last Post: 03-18-2007, 10:50 PM
  3. Wiring up crossover devices ??
    By Kurack in forum Car Audio
    Last Post: 03-01-2007, 12:24 PM
  4. Replies: 7
    Last Post: 12-20-2005, 11:08 AM
  5. Noise floor and crossover levels
    By skarsol in forum Car Audio
    Last Post: 06-14-2005, 07:52 PM
