Results 1 to 5 of 5
Thread: Becker 7990 Grand Prix on a W210 Mercedes....
    Sep 2007
    Cheers people,
    I am very interested to get the Becker 7990 http://www.mybecker.com/beckerCms/ww...003&navSeq=224
    for my Mercedes W210; However I have some questions:
    Will this fit my car?
    If it will; will it fit as plug and play or not?
    Thanks.
    Sep 2007
    Seattle, WA
    I would suggest one of the MB specific forums:
    http://www.mercedesshop.com/shopforum/index.php
    http://www.mercedesforum.com/
    There are a few others.
    Juan
    Sep 2007
    anyone?
    You can download the manual at the same site to view the DINS connectors:
    Here is the manual http://www.mybecker.com/beckerCms/ww...tion_Guide.pdf
    Here is an images:
    Variable Bitrate Bimmerstyle's Avatar
    Sep 2006
    Belgium
    It looks af if it has a universal ISO connector so with the right wiring harness it fit's any car. Only the connections at the top are strange. I guess Becker has put a connector with the radio in the box to convert those connections into more universal one's. Maybe you can contact Becker for more specific details of the radio.
    For over years now Becker is the suplier for OEM Mercedes headunits, so if there is one car this radio should fit in it's a Mercedes. But since every car manufactorer uses his own specific connector and these on the radio are universal ISO connectors, chances that it will fit plug and play with no additional wiring harness are slim.
    BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
    Bezel Worklog-My Install -iDrive F01 RR Skin
    Sep 2007
    Just for the update of the subject and for sake of others seeking the same question to be answered; I got a confirmation from Becker that the unit will work on my car without any cable modifications as it turned out that my factory Mercedes player is a Becker BE2210, here is the response:
    "Pinning of socket A (supply voltages and special functions) is pin compatible. Socket B (loudspeaker) is compatible as well.
    But only socket C is not compatible neither in connector dimension nor in function.
    Consequently the BE 7990 can be installed by using the existing and present connector of the car (A+B)
    with kind regards
    i.A.
    Roger Hertel
    Harman/Becker Automotive Systems GmbH
    Quality Customer Service (QCI)
    Tel. +49 7248 71-1210
    Fax +49 7248 71-1246"
