Are you just wanting to go from 1/4" to RCA?
If that's the case: http://www.vandenhul.com/artpap/wiring7.htm
Do the Zapco amps require a special input for signal?
i want to run a m-audio 1010 with the balanced lines straight into the zapco amps, and somehow use balanced inputs, i was thinking of creating my own cables to go from the balanced m-audio to the s-video type symbilink input.
anyway i have sent zapco an email but maybe somebody here has an answer?
Jan Bennett
I know Robert usualy will give the pinout diagram for the symbilink din connector. You would have to do the same from M audio. Who did you send your email to at Zapco? If it was Robert he normaly gets back to people very quickly. You could also do the method Red mentioned and use the symbilink transmitters, Im not sure what the voltage you get out of the M Audio piece is but you do get up to 12volts with the transmitter.
On the Refrence amps you can run RCA or balanced in on all but the 500.1 and 1100.1 mono amps, they have to use the symbilink transmitter and go balanced in. Zapco sends a transmitter with all their amps to go from RCA to the balanced symbilink though so the customer has an easy integration option.
Aron
Absolutely 100% stock
zapco has some interesting inputs...
zapco uses mini din 6 with balanced in. since he is using a card with balanced out's he is in the right state of mind retaining the balanced signal.
here is the pin out:
if you're looking for an zapco active x-over let me know, i just happen to have an slx-4 laying around that i'm looking to unload
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
hey I forgot that image was in the manual. Thanks Scott
Aron
hmmmm now that i see the symbilink wires my grand plan my just grind to a hault, where am i supposed to get the +/- 15 volt and ground from? i thought the symbilink was just +/- ground left/right not the 15 volt thing. hmmmmmm
ignore the +/- 15 volt. that is just there to power stuff like crossovers, eq's, dacs, etc... you can still wire it like you have planned (that's how i have mine wired). if you were going to add; say the slx-4 that i'm selling, you would make a special cable to go from your soundcard to the crossover then a symblink cable from the xover to the amp. the power from the amp will power the crossover via the 15v lines on the symblink cable (btw if you want to save money...symblink = p/s2 extension cable)
M10k
My Car Pc Install
My Boat Pc worklog
Not entirely true. The Zapco Symbilink cables have a latch that keeps them locked in unless you push on the top (PS/2 doesn't have this, the Rockford Fosgate and Soundstream models that had balanced back in the day didn't have this cool feature either).
Probably in most cases it doesn't matter, but there are advantages to going with the real cables.
Juan
M10k
My Car Pc Install
My Boat Pc worklog
