There are 1 ohm mono stable amps, but they are few, and fewer still can run that low a load consistantly without breakdown. If you are looking to use that subwoofer I recommend running it in series for a 4 ohm load instead of parallel for a 1 ohm load. There are many fine amplifiers to choose from that will run at 4 ohm mono all day long.
As far as multiple subs, the final impedence load is the key here as well, not the number of speakers the amplifier is driving.
LinkBack URL
About LinkBacks
