Results 1 to 5 of 5
Thread: Output from Carpc to Amp
    Aug 2007
    Hi
    I have got a Dell SX260 setup and a small amp to power the speakers, i would like to know if i can take the On Board sound output (from the Greenplug) into my amp or does it need to be a line out from a usb sound card?
    Maximum Bitrate S4Per's Avatar
    Jan 2004
    Seattle, WA
    You likely CAN use the onboard output, given you have a cable that has the right connectors on each end. The question is around the quality of that output and if a USB sound card would provide higher quality (likely it will).
    Aug 2007
    thanks
    found this FAQ as well http://www.mp3car.com/vbulletin/advf...ew&advfaqid=29 (couldn't find it before, blind as a bat) which helps,
    I have got a cable which is 3.5 mini jack to 2 x RCA, one more question, if i did use the onboard, would i take it direct to the speakers or to my amp then the speakers?
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    you would go from onboard -> amp -> speakers
    onboard wouldnt have enough power to drive speakers
    _
    Mar 2004
    Little Elm, Texas
    Don't be surprised if you're not happy with the quality of the sound coming from the onboard audio....if you aren't happy with it then move to an upgraded sound card (PCI/USB/Firewire/etc.)
    Jan Bennett
  1. Amp behavior.
    By enitalp in forum Car Audio
    Last Post: 05-01-2006, 09:06 AM
  2. Powering carpc and amp
    By bjfrank in forum Car Audio
    Last Post: 04-11-2006, 02:32 AM
  3. Replies: 20
    Last Post: 10-31-2004, 10:53 PM
  4. amp for EPia-10000M audio output
    By loscooby in forum General Hardware Discussion
    Last Post: 02-08-2004, 04:49 PM
