Results 1 to 4 of 4
Thread: Which cable do I need?
    Jul 2005
    My headunit has a headphone jack on it, and I'm connecting an mp3 player with the same headphone jack on it. I have a cable that has a headphone male end on both ends and when installed I only get sound out of one channel, but if I retract the cable just a little I can get both channels.
    Now...If I take a headphone to RCA adapter cable and use a double female RCA adapter to connect 2 headphone to RCA cable adapters, they work fine.
    I just need to know exactly what cable I need to connect these 2 devices via the headphone jacks to get both channels.
    Thanks.
    Elsewhere
    A stereo line in cable.
    It will have the 1/8" headphone jack on both ends. It sounds as if the cable you have is either mono or damaged.
    How about the Wiki?
    Oct 2007
    Yeah, it sounds like you need a stereo cable. As dumb as it sounds, most portable devices come with a single channel mono cable.
    Oct 2007
    A good way to identify which one you have: If the plug has two little "black rings" around it, it is stereo, if it only has one, then it is mono.
  1. Messed up VGA/USB cable
    By carfreak01 in forum LCD/Display
    Last Post: 08-19-2005, 07:08 PM
  2. VGA Cable Question (Pinouts)
    By Bugbyte in forum LCD/Display
    Last Post: 07-26-2005, 09:54 AM
  3. FS: Modded Xenarc 20-pin Cable - 6 foot
    By hd54321 in forum Classified Archive
    Last Post: 05-27-2005, 03:54 PM
  4. Need help on extending the Lilliput cable
    By nthai in forum LCD/Display
    Last Post: 04-27-2005, 01:59 PM
  5. FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP!
    By 1300mer in forum Classified Archive
    Last Post: 08-13-2004, 02:47 PM
