constant popping while playing or just at startup?
Search for "turn-on pop" if it's just at startup. There are multiple ways to get rid of it. Are you running it to an external amp or to a headunit?
hello I have a creative usb audio apatoor that makes m car sound about 3000x better. very goos clear sound unlike the soundcard in the jetway 1.5 I have. (its sound like sheet) anyway this setup is perfect for me and I love it but the one problem is I get no popping from the stock sound card , but when the creative usb soundcard is attached it has this popping problem , how can i ground the sound car and do you think it will work?
System always under construction
its not on start up at all
thank you though. It is the entire time the songs are playing. they re very scattered pops the entire time of play. very annoying.
try putting the creative device on its own USB port, not through the a hub. External soundcards are USB-bandwidth hungry and don't like to share. That is what the popping is from. Sound like rice crispies, right?
i d not have it runnin off a hub. but i will try to switch usb ports and see what that does. any other ideas
What card is this?? Apatoor? Never heard of it. Is that the correct spelling? I thought I knew about most Creative cards.
its the firmware versions for the bios, try updating with the latest one
wrap the creative USB soundcard up in foil. If its interference, it'll take care of it!
...Then boom when the foil shorts it out
Unless of course the Apatoor in question is already in its own protective case![]()
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
I have a similar problem with my external extagy I think. At first I thought a small rock had hit the windshield. Does it sound like this? I don't have it very often though. Ones in a couple of days or so. So I don't really mind.
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog-My Install -iDrive F01 RR Skin
