Results 1 to 7 of 7
Thread: zapco: 360.4 vs DC360.4
    Nov 2006
    Thornhill eh?
    ok, so i tend to follow "if your going to do it do it right" so with that said i need input on amplifier choice.
    Ultimatly i want my PC as the source unit which will control EQ/time delay/crossovers and all that fun stuff, or so i hope. I am using a m-audio 1010 'sound card'
    So if my computer will be doing that is their any real argument as to getting the DC amp? i can never see myself running 1/2 or 1 Ohm loads and other than that i cant see the DC being anymore useful, other than it looks better and has some nifty surface features (flush terminal things)
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    If you will be controling all processing through the PC then you should be fine with the regular REF amps. You will not notice any more power going to the DC amps. I can vouch the REF 360 is an awesome amp.
    Aron
    Absolutely 100% stock
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    i'd say either one of them is doing it right. are you competing or is this just for your enjoyment?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Oct 2007
    What software and hardware are you using in your pc that can perform on par with the DSP in the DC amps?
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Old thread i know, but my Search button was working today for some odd reason?
    Does anyone know how(and if) under rated the zapco 360.4 is? I know the DLS's say 50 as well but they bench at like 75-85 easily; i am curious to know if this is the same case as Zapco?
    screen name here use to be MegaloRESE15"
    Apr 2005
    2hr west of Chicago
    Their birth sheets dont give away to much info on the ref amps as far as 4ohm power per channel. They only rate it in a 4ohm bridged config, both of my 360s showed very similar.
    Aron
    Jan 2006
    The Colony, TX
    and thats max BURST power too, anyone have a clamp
  1. zapco amps (kinda)
    By brendan in forum Car Audio
    Last Post: 11-01-2008, 05:40 PM
  2. FS: 12w7, eu-700, & Zapco x-over
    By scott_fx in forum Classified Archive
    Last Post: 03-10-2007, 04:27 PM
  3. Zapco Reference 1100.1 via USPS
    By Megalomaniac in forum Car Audio
    Last Post: 02-23-2007, 04:33 PM
  4. FS: Zapco iForce I-2100 & I-450
    By migel628 in forum Classified Archive
    Last Post: 09-24-2005, 01:23 PM
  5. ebay: Zapco AG1000
    Last Post: 08-03-2004, 02:01 AM
