It all depends on the amp and speakers. Why are you doing this in the 1st place? there will be no benefit over running it in stereo with running them in a series. If they are 2 ohm subs and the amp is 4 ohm mono capable then there is a reason.. the amp will act if it has a 4 ohm mono load but 2 4 ohm subs in a series will be 8 ohm mono this config has no benefits over 4 ohm stereo .
LinkBack URL
About LinkBacks
