the midbass wouldn't be mono. actually...i wonder if this would work. s/pdif to the behringer. remap inputs 1 and 2 to be pass through outputs. then wire those outputs to your sub amp and use the amps x-over to control the sub.
i think that may just work. you have to look into it and make sure you can remap the inputs to pass through though
edit...just opened up the program and i dont see a way to set the inputs to outputs. but still if you are going out of a soundcard analog(ly?) you could just get a y- splitter for both chans and hook it up as i described in post 21
LinkBack URL
About LinkBacks
